Question about Radio Shack Cinego D-1000 Multimedia Projector
Auto shut off
My projector has started to shut off after five to ten minutes. I have 1643 hours on the bulb. Does anyone know why this is happening?
  • 3 more comments
  • JayJayJoe Nov 21, 2007
    My projector has very few hours on the bulb and is automatically shutting off after 10 minutes.
  • flevel Feb 19, 2008
    I have same issue... has anyone tried returning this projector to Radio Shack for repair???
  • Anonymous Feb 24, 2008
    where do you get the heat regulator changed?
  • fastfootdad Jul 24, 2008
    projector turns off after 30 minutes of use
    even after i bought new bulb
  • variax Aug 03, 2008
    Mine lasts about a minte before turning itself off. It's NOT the bulb -- because it does project a picture while it's on. It must be the heat regulator as mentioned here. Where can I get one of those?
I've noticed the same thing with mine. I have noticed that the more ventilation it gets, the better it functions. I've just been letting it cool, then turning it back on.
Posted on Jul 09, 2008
Does anyone know how much it cost to repair it the regulator
Posted on Jun 28, 2008
I had the same problem i had the heat regulatoer changed and now it works like a champ it is great i have never had a issue with mine after i changed it so try that
Posted on Feb 23, 2008
I have 3 Cinego projectors and none of them work now only after about 5 months use. You will never find a solution for this issue. Cinego is a terrible product and should be blown up!!! I'm very pissed off that no one can resolve this issue that everyone seems to have.
Posted on Feb 20, 2008
Same problem for me with a new lamp and it shuts off after 10 seconds or so.
I have been unable to get an answer from anyone....hopefully someone here can help
Posted on Feb 11, 2008
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
Shuts off after approximately 2 minutes
I have exact same problem. According to the manual its time to replace the bulb. But when I check the runtime on the bulb it shows 326 H. I am not certain if this is the remaing hours on the bulb or the usage to date hours.
I would appreciate anyone commenting and recommending a solution.
Jun 13, 2010 | Panasonic PT-AX100U-EC DLP Projector
Projector randomly turns off after 10 minutes or so
Go to the OSD menu and select the configuration menu scroll down and select the auto power off selection( in most cases it is preset to power off after ten minutes of inactivity) turn the auto power selection off and there you go!!!!!!!!!!!!!
Mar 11, 2010 | ViewSonic Cine1000 Multimedia Projector
Projector keeps shutting off and red light comes on
We had a projector at our church that was hooked up to a light switch to turn it on or off and it kept burning the bulbs out. We had an expert come in and look over our situation and he said When you are finished with the projector let the fan keep blowing until the unit cools down. Ours had a switch for the bulb as well as one for the fan. We turned out the bulb and left the fan on for an extra ten to fifteen minutes. That let the bulb cool down gradually If you just cut the power the bulb over heats and will burn out. Yes turning on for a few minutes will burn it our quicker as well. Hope this helps.
Mar 14, 2017 | Dell Projector Lamp for 2400MP
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
254 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Jerry Greenberg
Jerry Greenberg
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
