Question about HP Pavilion Media Center M1090n (PC100A) PC Desktop
Connecting power supply to peripheals
Where can I get an illustration showing all the power connections in my HP Media Center 1090 n computer?
Thanks
Jerry
  • 69 Answers
U can get them from the internet try and go to the website related to your hardware, type in the model number in the search bar.
Please let me know hoe you get on.
Good luck
Philip
Posted on Dec 07, 2008
What is the power supply
The PC power cord is connected to a power supply inside what most people call the computer, the big box with the power switch. The power supply is a transformer, changing AC power to DC of various voltages to power the internal components of the computer.
Jul 14, 2014 | HP Media Center m1080n (PC099A#ABA) PC...
Install power supply
Relative easy. Open up the case and be careful to see what wires are connect. Replace each one carefully. There is the big wire that containes a bundle. This goes to the motherboard. There is only one way to install it. There is a 4 prong molex wire that goes to the hard drive. There are extra wires just in case you need to add another hard drive for example. There shoudl be 4 screws holding the power supply in place. Remove them from the back of the PC
May 07, 2010 | HP Media Center M370N (DM163A#ABA) PC...
Power Supply for HP Media Center m1270 PC
Are you sure it's the power supply?
Most modern power supply units are of the ATX type. Brand should not matter. Your PC used a 300 watt power supply when new. You can purchase a power supply with more output (watts) if you like, but not less. You will have to purchase from a computer specialty store most likely - take the dead one in and compare it side by side with the new one before buying.
Dec 11, 2009 | HP Media Center m1270n (PP132AA#ABA) PC...
I have a HP media center m7360n , with a 920 intel pentium D processor. I changed the video card which required a more powerful power supply. I upgraded the ram and changed the power supply out to be...
Open your computer casing where the motherboard lies in and then remove the memory card, your new video card and then reset the BIOS, refer to the motherboard manual on how to do it. After resetting, plug in the memory card and video card. Close the casing and connect all the wiring. Power up your computer.
Nov 03, 2009 | HP Pavilion Media Center TV m7360n...
Hi all...!!! Power failed and came back minutes later. Can't start HP Media Center M7060n Green light on back flashes slow when power not connected, slower when power cord connected but I press the ON...
On HP computers, I believe that this means that the power supply or the motherboard is bad. I assume that the outage was due to the thunderstorm and you may have received a surge. In your manual, there should be diagnostic light codes where they will outline the exact meaning. Again, to the best of my knowledge, this means that there is a bad power supply or a motherboard.
Jun 10, 2009 | HP Media Center m7060n PC Desktop
Computer will not turn on. Power supply shows flashing green.
depending on the make of computer, a power supply cost's around $20.
Mar 12, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Evesham ebox - Sleep function
Hi, Azrul here, from Malaysia. You can disable the sleep function for your HP Media Center m7250n before connecting to tv.
Go to control panel
then go to display
then go to power under the screen saver's tab
then set your power options to never go to sleep at any settings.
Dec 21, 2008 | HP Media Center m7250n (ED842AA) PC...
Question about the flashing green light on hp pc
Your best bet is to get a new power supply put in because then your not wasting a lot of money on getting the computer serviced every time it happens. So what I think you should do is get a new power supply because it's not only the cheapest route but also the best route to go right now. If the CPU board continues malfunctioning after you install the new power supply then that right there is showing that you need a new CPU board.
Nov 02, 2008 | HP Media Center m7060n PC Desktop
Hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Jul 11, 2008 | HP Media Center m7060n PC Desktop
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
POWER SUPPLIES HAVE AN INDICATOR LIGHT FOR A REASON.
REMBER - BLINKING LIGHT IS AN OVERLOAD OF THE PROTECTORS AND ELLIMINATING THE OVERLOAD SOLVES THE PROBLEM AND THAT THE POWER SUPPLY IS WORKING AND CONVERTING POWER.
NO LIGHT MEANS NO POWER OUTPUT AND THAT INDICATES THE POWER SUPPLY IS NOT FUNCTIONING AND NEEDS REPLACED.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
HP Pavilion Media Center M1090n (PC100A) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
