Question about Saeco Royal Exclusive 30153 Espresso Machine
Watertank Empty notice when tank is not empty
I took the cover off and flushed the tubing that goes from the resivoir to the white device that flows water to the pump (?)  What could be the problem?
  • 5 more comments
  • dniym9 Dec 07, 2008
    Both have already been checked. Its more complicated than that..
    I do not think you are giving me instructions on the Saeco Royal Exclusive.  I do not see the 2 metal rods or conductors attached to the machine
  • dniym9 Dec 08, 2008
    I cleaned out the o-rings that are under the water container and it seemed like it worked, but now its telling me "brewunit block."
    whats wrong with this thing
    Marked, Thanks for the detailed response. I followed your steps, but no luck. I also pressed all the other buttons and heard the grinder go and heard the brewunit go through the motions, but I am still getting brewunit block.
    I am assuming that is why when it does the self test, it does not sound like its winding up or make that start up noise.
    I think the watertank empty appears to no longer be an issue. Now its a matter of this brewunit blocked
  • dniym9 Dec 09, 2008
    I appeared to have fixed the watertank empty issue, but b/c of it I think I may have shorted out something else and that is why its telling me brewunit block.
    Any repair center recommendations in South Florida?
  • dniym9 Dec 14, 2008
    you are hilarious. How about you give up the comedy bit and stick to your day job?
    Can one of you explain how to reset the brew unit?
    Genius:
  • 1,011 Answers
Sir,
Click this link to reset the unit...
thanks
good luck
Posted on Dec 14, 2008
  • 88 Answers
Throw in trash and buy new one,hope this helps.
Posted on Dec 09, 2008
    Genius:
  • 1,199 Answers
The water sensor is broke and must be replaced, have a pro do it!
Posted on Dec 08, 2008
  • 365 Answers
This is a common problem which i have also experienced.this is only due to the vibration of a small 'bullet' like white material inside the system which controls the water flow .try to tight it anyway and you can reduce the noise by allowing a small quantity of water to enter in(by turning the main valve to the low level which will allow the minimum water flow).no need to worry about this
  • JITHIN ANTONY Dec 08, 2008
    have you checked all
  • JITHIN ANTONY Dec 14, 2008
    i think the problem is solved
  • 6,487 Answers
The reset command sequence for resetting the brew to Reset Position is;
1. Close the Door.
2. Press and hold simultaneously the Hot Water and Small Coffee buttons.
3. While holding the buttons down, turn the mode knob to On with Light. At this moment, the screen will show a version number and other numbers. The unit is now in maintenance mode.
4. Release from pressing buttons.
5. Press and hold Medium Coffee button. This will move the grinder into "home" position for extraction and cleaning.
  • Mark Gil
    Mark Gil Dec 08, 2008
    No problem if that's teh case I suggest you take this already to a repair center to have this unit check to avoid further damage , because sometimes some parts needs to be replace already...
  • Mark Gil
    Mark Gil Dec 09, 2008
    You can take it here
    5201 Ravenswood RD.
    Ft. Lauderdale, FL 33312
    this is their web site http://www.fortheloveofcoffee.com/about_...
    Genius:
  • 1,239 Answers
HI
Often the problem is the reservoir sensors think the water tank is empty. The metal rods that go into the white plastic tank are the sensors, and they contact the sides of the machine to provide an electrical ground. The water needs to be normal tap water, distilled water will not conduct...
At any rate, the fix is to simply jiggle the tank left to right to roughen up or clean the contact between the sensors and the body of the machine. Within a few minutes the machine should start to heat up, now that it knows you have water.
Hope that helps!
Posted on Dec 07, 2008
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    OR
    Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all
  • ABHISHEK.C
    ABHISHEK.C Dec 08, 2008
    The brew unit sensor may have become disconnected from the main circuit board. If you are very brave, you can UNPLUG THE UNIT, remove the top panel and check that all the wires running into the circuit board are connected.
    Otherwise, the sensor may have failed and this will require service.
    You can remove the brew group by following the "how to remove a jammed brew group?" on this pagehttp://cerinicoffee.com/Saeco_technical_...
    For Cleaning Supplies and Saeco Parts visit:
    www.cerinicoffee.com
  • ABHISHEK.C
    ABHISHEK.C Dec 09, 2008
    did  you read my last solution of bunet lock
    HERE  ARE THE SERVICE PROVIDERS
    A 1 Appliance Service
    Refrigerators, Ice Makers, Water Heaters, Washers, Freezers, Dryers
    Service Area: San Antonio
    Service Cost: Call for Estimate
    Rating: Read 1 Reviews
    Call:210 6988555
    Conway Television Service
    Service Area: Conway
    Call:843 2486716
    Arnolds Appliance Repair
    Service Area: International Falls
    Call:218 3774469
    Genius:
  • 1,550 Answers
Make sure the magnet in the water tank flow up.
You have to push down the water basket in the back.
How do I remove the toilet
what brand and type, if it's just a standard toilet, shut the water off first, then flush the toilet to empty the tank, then take a small plastic cup and empty the rest of the water from the toilet. disconnect the water supply tube from the bottom of the toilet tank. next remove the two nuts securing the toilet to the floor and lift it off the flange being careful not crack it. remember to cover the pipe in the floor so it doesn't stink up the hose and always install a new wax ring when reinstalling the toilet.
May 25, 2014 | Home
Rinsed my humidifier with water and wiped the base down, refilled it and now it seems to be making the mist in the base butbisnt making it's way out of the mouth of the dolphin
The tubing to the mouth of the dolphin or the misting nozzle is clogged with mineral buildup and scale.
To clean this, do the following.
Empty the water in the tank and replace it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the unit to sit for 30 minutes, then turn it ON. If mist does not appear within 10 minutes from the mouth of the dolphin. Turn the unit OFF and allow it to soak over night. In the morning, turn the unit ON and allow it to run. Once the mist appears where it should, run the unit until the tank is half empty. Then empty the tank of the remaining solution and refill with Bottled Distilled Water and run the unit until it is empty. This will flush all the remaining solution from the tank, tubing & nozzle.
In the future I would recommend using Bottled Distilled Water on a regular basis, rather than tap water. Doing so, will eliminate the problem of scaling.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | NewAir AU-200E Humidifier
Filled Watertank; water will not go open valve and go into mister area
It may be clogged with mineral scale. Empty the water that you now have in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Let it soak for several hours and then turn the unit ON. If it starts working as it should. let it run another 5 minutes, turn it OF and empty the tank. Refill the tank with Bottled Distilled Water and allow it to run at least 45 minutes to flush the system. After that, if you do not detect any vinegar odor, you can continue to use the remaining Distilled water.
If the unit didn't work as it should have after several hours of soaking. Turn the unit OFF and let it soak overnight. If this solved the problem, I would recommend that you continue to use Bottled Distilled Water for normal operation, rather than tap water.
Hope this helped solve the problem
Mar 22, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
Water is leaking out , close water off then water in tank goes empty. when water on you can hear water runing in tank
Your flush valve (flapper) is leaking. Some of these rubber flappers snap on to posts. Others, slide down the overflow tube. Others are the plunger type that lift straight up and down (some of these have a gasket on the bottom that go bad.) In any case be sure flapper closes properly. Make sure the chain to the handle isn't so long as to get between valve and seat holding flapper open. If all else fails buy a fluidmasgter flush fixer repair kit and follow directions. I had a similar problem one winter and wasted about 200.00 on water.,
Jul 10, 2010 | Caroma 270W-RF Reflection Round Front...
Installed new tank. Flushed fine 2 times, then
The flapper isn't staying open long enought, try holding down the handel for a few seconds each time u flush.
Mar 10, 2010 | Home
Venox wont start up after removel of gas tank for re spray
Hi Small vacuum tube goes to the inlet manifold, safety device to prevent fuel flow when not in use.
If you literally **** on it it will start and run!!
Dec 09, 2009 | 2003 Kymco Venox 250
We get the message Unit Cal.Fied - what to do?
You need to run the Decalcyfying program. Push and hold the button with the symbol that looks like a tube with small dots inside. You will get the message empty tray and empty grounds. Do so, and put everything back. The message Solvent or Agent in tank will be displayed. Meassure up 700ml water in a container, put 3 Descaling tablets in the water and let it be completly desolved before you pour this into the empty watertank. It`s very important that you don`t use more liquid, this will make the program run forever. When the solvent is in the tank, push the buttoun again, and the program starts. After a while (20 minutes or so) you will be asked to empty tray/grounds again and to fill the watertank. At this point you can fill up the watertank, this will not affect the running of the program. In the end, you must empty tray/grounds again, and after this the machine is heating up and ready to use. Good luck!
Aug 17, 2009 | Jura Capresso Impressa X90 Espresso...
Watertank empty problem
Couple of things.
Magnet in the water tank could have gone bad in which case you need a new water tank.
2. Sensor for the magnet could have gone bad. Which case you need a new sensor.
3. Flowmeter could be dead in which case it won't feed water to the system, If thats the case its a new flowmeter.
4. Pump. If the pumps not working, it won't feed the flowmeter, which in turn won't feed the system. You'd need a pump in this case.
Its one of the 4. Unfortunately its not an exact science, its a trial by error type thing.
Cheapest way is to send it to a service center. They'll know right away when they open it up. They can also diagnose quicker.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Saeco Royal Exclusive 30153 Espresso Machine Logo
97 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
