Question about Refrigerators
I need to know the power use / wattage of the kelvinator opal fridge - i think its a 200lt
  • 306 Answers
You can figure the power usage by taking the voltage x Amperage, That will give you watts. EXAMPLE 120 x 6 = 720 watts . there should be a data plate inside the fridge giving you the full load amps. Which is everything that draws amps on at the same time. Hope this helps. Any questions get back with me and I can help more.
Posted on Dec 07, 2008
My Kelvinator Opal Freezer is not getting cold, I think the compressor is not kicking in ?.
Probably the thermostat. You will need a multimeter to see if there is a circuit across the thermostat. There should be 2 wires and an earth to the thermostat. if you bridge the 2 wires together. (NOT the Earth or green wire) the thermostat will be bypassed. If the thermostat is faulty, the fridge will start but will not turn off when it reaches temperature. You will then need a new thermostat. Make sure its unplugged before you play around with it.
Nov 20, 2016 | Kelvinator Refrigerators
Kelvinator opal after shifting,it only starts for a minute and stops will not keep going
did you turn it on its side if you did stand it up for 24 hours unplugged from the power then plug it in and see what happens
Nov 19, 2014 | Kelvinator Refrigerators
Kelvinator opal
Replace the defective fan motor
Nov 13, 2017 | Refrigerators
Kelvinator opal
for this you need an expert to put more liquid into your refrigerator to return to normal
Dec 15, 2013 | Refrigerators
Hi My Kelvinator Beverage Cooler fridge has packed up due to power surge. If possible please could you email me a quotation as i need to purchase another one. Description: 1 door which is glass and its...
Hi.
The price depends on the model and on the internal volume. Here a UK seller: Commercial Beverage Coolers & Commercial Bottle Coolers. Here a SA distributor of beverage coolers. The choice includes Kelvinator.
About the fault. If the problem happened after a power surge it is often possible to repair the cooler replacing the starter relay mounted on top of the compressor. The part is not expensive. Call the Kelvinator number listed on the owner manual to know more about the possible repair or to purchase the part.
Regards.
Ginko
Sep 13, 2011 | Kelvinator Refrigerators
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
How do i drain a drip tray in a kelvinator opal fridge
you should not have to drain the pan,water should evaporate,check for leaks from water lines
Jan 10, 2010 | Refrigerators
Kelvinator Opal CS 390 F door has dropped down on handle side.
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
Apr 26, 2009 | Refrigerators
Hinch for Freezer/Fridge doors is broken,Kelvinator/fridge Freezer Model Opal-N520F-L My address is 30 Murraba Crescent, Tweed Heads 2465, NSW Where can I get the part
Thanks for the reply,
I solved the problem by finding an old warrent card with aphone number which I rang and was tild a nother number and that Electrolux is holding parts for Kelvinator, the nearest Electrolux branch for me was at NERANg a 30 minute drive. Their had the spare part for $20 and I replaced the hinch with a spanner. All is well as good as new.
Amazing how would one know that Elextrolux is holding service parts for Kelvinator, Westinghouse and others, unbelievable really
regards
Ziggy Mireis
Jul 06, 2008 | Refrigerators
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
