Question about Dryers
We just moved into our new house and needed to change the electical plug on our dryer. Wondering which wire goes where - they are colored on the cord and on the dryer, but none of the colors are the same to match them up. How do we know which wire connects to which?
    Genius:
  • 2,920 Answers
Red black and white shouold go on in that order and the green if there is one is a ground wire
Posted on Dec 07, 2008
Hi, I live in Argentina and I have a kenmore 96093800 Dryer. This Machine has 120/240v and his plug has 4 pins. Two pins are flat, one pin is cilindric, and the fourth pin is en angule. How can I connect...
Are you connecting this Dryer cord to the Dryer or are you looking for a wall plug with this same configuration to plug into. This is a standard double ground configuration and you can buy the wall receptacle at a hardware store. Your house should have 4 wires to this, 2 lines, a neutral, and a ground. As always the recommendation is that you have an electrician install your house receptacle. Your Dryer power cord is something you can install however. The two outside terminals on your dryer 240 volt wiring block are connected to the two outside wires on your power cord. It does not matter which wire goes to which side. Your two inside wires on the power cord are connected like this. One to the middle terminal on your 240 volt dryer terminal block and one is connected to the dryer case itself. Again it does not matter which wire goes to which ground. Make sure all of your connections are tight, as loose terminals eventually burn up. Do Not plug in your dryer power cord until everything is hooked up tight. I actually had a customer plug in his cord and then try to connect the wires to the dryer. The wires arced together and blew the terminals into molten metal which burned this customers hands and face. Do not do and electical repair unless you know what you are doing. On your cord the two straight terminals are line terminals, the round and L shaped terminals are grounds or neutrals. Good Luck, Appliance Specialists
Dec 15, 2009 | Washing Machines
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
How do I change the 4 wire to 3 wire plug
Move dryer away from wall. On the back of the dryer, near where the power cord goes into the dryer, there should be a small access panel held in place with 1 or 2 screws. Inside there should be 4 screw terminals. They may be color coded red, black, white and green. Make a note or take a picture of it before you go any further. Loosen the screws that hold the 4 wires of the old cord and remove. Install the new 3-wire cord, note that it will not have the green (ground) wire on it. After all is put back together, you should be good.
Nov 10, 2009 | LG DLE2514 Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
I moved to a house with a three prong outlet for my Frigidare electric dryer, model number FER341AC0, that has a four prong cord. I bought a new three prong cord but there is no color coding on the dryer...
The three wire goes on the electrical block on the back of your dryer just like the cord is made. If you look at the cord, it's made flat (Most 3 wire cord are made flat, Some are not) The wire in the middle goes in the middle of the block. The two wires to the outside go to the outside of the block. It makes do difference which wire goes on which side as long as the outside wires go to the outside.
Please rate solution
Sep 06, 2009 | Frigidaire GLER642A Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
I have to change the plug on a whirpool drier as the wall plug at the rented house is different. i have bought the new cord to install and when i took the cover off the old wiring, all wires are grey and...
ok on the terminal block looking in from the back you have 3 terminals on your new cord there is a Black a red a white and a green the Black goes to the far left terminal the white goes in the center terminal the red goes on the left terminal the green goes to gound or a green screw on the back of the unit if there is not a green screw then use the screw that holds the cover plate on
Aug 20, 2008 | Dryers
I've since moved and in the new house the dryer cord had a 3 pronge plug. The one that I need in the new house is a a 4 pronge plug. I purchased one, took off the 3 pronge plug without looking at the...
Yes, it does matter which color wires are connected. If connected wrong, you may injure yourself and/or destroy the dryer. The following link explains how to convert your dryer plug:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Let me know if you have any further questions. I hope this helps you.
Aug 07, 2008 | Dryers
GE electric dyer cord
You must change the cord on the dryer. New house constuction electrical code requires a 4 prong receptical (double grounded).
You can buy a cord at Lowes, Home depo, Sears, etc. When you install the new cord there is a brass strap from the neutral post to the dryer cabinet that you must remove.The extra green wire in the cord connects to the cabinet. Your old cord probably won't be color coded, but the new one will be. Red is hot, goes on the end post, (doesn't matter whichn end). white is neutral and goes on the middle post. black is hot & goes on the other end post.& green goes to the cabinet.
Nov 12, 2007 | Dryers
Dryers Logo
Top Dryers Experts
