Question about InFocus LP 435Z Multimedia Projector
Lamp problem? Hi, I already replace the lamp on this projector, the projector turns on but not the lamp... is it possible that the lamp replacement is damaged?, when you replace a lamp on this projector, you should do something or just plug in the new lamp?. Thank you in advance.
  • 31 Answers
The problem could be related to a fan or heat sensor. The lamp could be faulty but new lamps tend to be pretty good as far as reliability. Just make sure the lamp is sititng absoultely firmly in the correct position...normally you would plug in and switch on. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Posted on Sep 09, 2009
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    My viewsonic 3d projector won't turn...but it has
    You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
    Aug 22, 2011 | ViewSonic Televison & Video
    Turns on and calls for replace lamp, I already did it and still calling for replace lamp. Fan turns on and that's it power and lamp lights are on thanks
    Projectors keep a lamp life clock to track the age of a bulb. The clock needs to be reset with each bulb that is inserted. Here are the steps with your particular projector:
    1)Power on projector
    2) Go to "menu"
    3) Choose "Options"
    4) Choose "Lamp Settings"
    5) Choose "Lamp Reset"
    6) Select Yes
    Certain models require you to hold "Lamp Reset" for a particular amount of time. It could be instantly, 3 seconds, 5 seconds, 10 seconds... Just have to play until it responds.
    Once that is reset you should be good.
    Mar 08, 2011 | Optoma PRO250X Projector
    I have a model and swapped the T45U projector lamp, the projector turns on, but in a few seconds it shuts off, and turns on the LED "Temp" what can this be?
    hi,
    First of all check the lamp hour . Reset the lamp hour and try again. It is recommended that reset lamp hour only after replacing the lamp. No matter, just reset the lamp hour. If problem doen't repeat the try to replace lamp.
    Another possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
    ok
    Feb 12, 2011 | Toshiba TDP-T45U DLP Projector
    Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
    hi,
    its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
    1 Press and hold the Exit (up arrow) button on the projector for 5
    seconds to display the total used lamp time.
    2.Press Auto button the projector or on the remote control to
    reset the lamp hour to "0".
    3. Wait about 5 seconds to let the OSD disappear.
    ok
    Dec 22, 2010 | BenQ PB6110 Multimedia Projector
    I need to replace the projector bulb
    hi,
    for replacing the lamp do the fallowing.
    1 turn off the projector and disconnect the AC power . allow the projector to cool for at-least 45 minutes.
    2. remove the screw at the bottom to oppen the lamp cover.
    3. after that remove 2 screws of the lamp and pull out lamp by grasping the handle.
    4. replace the lamp with a new one and tighten the 2 screw s back in to position make sure that the lamp is set properly. replace the lamp cover and tighten the screw.
    5. connect ac power turn on te projector and go to the menu select lamp counter make it zero
    Replacement lamp type number is : POA-LMP90
    OK
    Dec 15, 2010 | Sanyo PLC-XU73 Multimedia Projector
    Projector turns off
    It sounds lamp is dead in this projector and need to be replaced.
    Lamp replacement procedure would be written in user manual so check lamp accordingly.
    Thanks.
    May 28, 2010 | Hitachi CPX2510N Projector Lamp
    Nec vt470 lamp does not come on. replace lamp, when turned on status light turns red and get 3 beeps. lamp does not come on.
    If you replaced the lamp already, chances are the ballast is defective. When you power on the projector with the power button you should see a flicker of light in the lens, or an electrical sound. If you don't you ballast is bad.
    Apr 19, 2010 | NEC VT470 Multimedia Projector
    Optoma ep 706, lamp lights on,replaced lamp, still not working
    moz-screenshot.jpgmoz-screenshot-1.jpghello,
    This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
    Bye.
    anytony2004@yahoo.com
    Aniekeme Anthony.
    I
    Jan 21, 2009 | Optoma EP706 DLP Projector
    InFocus LP 435Z Multimedia Projector Logo
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
