Back to:
Tags:
Sun Aire Sun-Aire Air Purifier - Stainless Steel, Permanent Filter for areas up to 2,000 Sq Feet Air Purifier
How often do I need to replace my filter?
By Janice - usenet poster
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2007
FixYa! (100)
SUN AIRE
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Since this is showing a picture of our SUN AIRE purifiers we build here in AMERICA, it is important for all to know our pre-filter are LIFETIME/WASHABLE 0.5 micron 2-stage electrostatic and NEVER need to be replaced. Our pre-filter serves two purposes; to filter your air down to 0.5 microns and also to keep the inside of your SUN AIRE purifier unit CLEAN and MAINTENANCE-FREE! Simply take the filter to your sink; spray it with your sprayer pushing the particulates out; let the water drain out the two drain holes on the end of the aluminum frame; wipe it with a towel and put it back on your unit. NEVER needs to be replaced and you save about $100-200 per year in expensive replacement filters with SUN AIRE purifiers!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How often do I need to replace my filter?:
I don't want to Accept this solution
Solution #2
posted on Aug 08, 2005
Not Rated (0)
Ranny
Rating: 0%, 0 votes
The carbon filter needs to be replaced every 3-6 months depending on usage, while the HEPA filter needs to be replaced every 12-18 months depending on usage.
Thank You!
Solution #3
posted on Dec 27, 2007
Not Rated (0)
ekwade
Rating: 85%, 2 votes
If you are using an EcoQuest Fresh Air purifier, there are NO filters to replace. You just need to vacuum it and clean your 03 plate every 30 days.
Thank You!
Solution #4
posted on Aug 22, 2007
Not Rated (0)
Mckheean
Rating: 0%, 0 votes
For the defender If you r a non smoker replace the black filter every 8-12 months. smokers need to change it 6-8 months. the white one needs to be changer 12-18 months. for the majestic. change it when the bucket is full.
Thank You!
Can you Help with these Air Purifiers problems?
Air Purifiers
I have an Ionic Breeze GP; however, the instruction manual...
Air Purifiers
i have a bionaire BAP825RC Purifier, which i bought 2...
Air Purifiers
i have water on my floor under the frig. i turned off the...
Air Purifiers
I'm looking for the fibreglass "springs" that...
Sun Aire Sun-Aire Air Purifier - Stainless...
I am just looking for a user guide or manual for the...
Loading problems.
Repair Service
Find Air Purifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
