Technics SA GX490 - Overload
My Technics reciever has been working well for years, I suppose it is getting a bit old. Last week I connected ny laptop via the headphone jack and after a while the sound stopped and "Overload" appeared on the screen. Now any application, c.d., tuner, video is triggering the Overload. Do you know if this can be fixed?
  • 905 Answers
Yes it can be fixed , the input may have shorted and is now protecting the other circuits. it will need to be looked at and tested to make the repair. so calling and probably having to take it to, an electronic repair shop will need to be done.
Posted on Dec 07, 2008
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Technics SA-GX490 reciever
Disconnect receiver from power and open the unit. Localize fuse that is placed on small PCB between main transformer "big one" and rear panel.Fuse's amperage is 1.6 A .I'm quite confident that fuse is gone.If so, replace it with the one of same amperage and try unit.
My unit has done exactly the same to me with no reason.
Radek
Sep 05, 2008 | Technics Audio Players & Recorders
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Feb 23, 2008 | Technics SA-DA10 Receiver
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
Open Questions:
966 people viewed this question
 Grubhead
Grubhead
