Question about Mitsubishi WS-55807 TV
Mitsubishi CK-3526R TV
Vertical Hold out. The picture likes to roll up and down rapidly, for a couple of moments. Has a tendency to do it when the picture on the screen is very white or light. There's no vertical hold knob to adjust.
I have no experience trouble-shooting tv's, but I'm savvy enough that if you give me complete directions, I'm confident I can open it up and work on it.
Thank you!
  • damon953 Dec 07, 2008
    Currently, all I have is the TV and remote. I don't have any of the tools or schematics you've mentioned. I have used a soldering iron before, so if the tools are inexpensive give me a list and I'll go get them. Thx.
  • jason May 11, 2010
    do you have soldering tools and the wick that takes the old solder off ?, and a meter for testing components? or access to a schematic for it?
  • 121 Answers
Not sure what light picture has to do with problem  but no there is no  vertical hold control  prob bad electrolytics invertical feed back circuit, need tech..
Posted on Dec 07, 2008
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
Continuous vertical roll on tv
Wow 5 months without a solution. NOT GOOD.. Well I hope I can help...
This sounds like a vertical hold problem, and is normally easy to fix.... There should be a couple of nob's on the lower back of the TV. One for vertical and one for Horizontal hold. You need to find the vertical hold nob and adjust it, until the rolling stops and stabilizes. If however these nob's are not visible you will have to take TV to an engineer to fix it.
Hope this helps..
Nov 11, 2010 | Zenith B27A11Z 27" TV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Intermittent vertical roll
if i had known i would have to pay for an answer i wouldn't have taken up your time. seems like everybody is jumping on the greed wagon. good luck with your website.
Nov 18, 2008 | Mitsubishi CK-27306 TV
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Tv problem
Good Day;
Sounds you have a bad vertical output IC that is defective along with some caps. Change IC > LA7838 > IC401 and ALL CAPS like cap off of pin #6 1ufd 25v and etc.
Good Luck, big IRISH.
Dec 12, 2007 | Mitsubishi WS-55807 TV
Vertical Hold Problem when connecting DVD Player
they have different resulutions they can synk
Nov 18, 2007 | JVC AV-32432 32" TV
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Jan 12, 2007 | Konka K2001UM TV
Mitsubishi WS-55807 TV Logo
194 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
