Rca p56923bl chirping
Ok it will be monday befor i can get another one if it does the same thing where do i need to look
    Genius:
  • 2,920 Answers
Test each circuit on the board one or more of them are going to be bad. it may take some time but it will tell you where the problem may be.that way you wont keep spending money on more parts ron
Posted on Dec 07, 2008
Will not turn on
See my tip at http://www.fixya.com/support/r4916941-diagnose_repair_projection_tv_high for help solving your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Aug 15, 2011 | RCA P56923BL 56" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
RCA hd52w59 out. Powerlight flashed 3x with chirp
Sounds like the Horizontal output transistor needs replacement.
May 27, 2010 | RCA HD52W59 HDTV Projection Television
Bowed out picture on rca projection tv
This unit has a problem in the pincushion correction circuit. These sets are famous for loose solder connections causing this problem. The Deflection PCB will have to be removed to repair this. You may want to contact a repair shop to help you out. Thanks
Oct 29, 2009 | RCA P56923BL 56" Rear Projection...
How hard would it be to replace a bad flyback and a horz. out. trans. without ever working on a television before? Could some help because I was it would cost 400 dollars if I had a repair man fix it.
replacing the fly-back itself is not enough. you need to check the components surrounding the transformer, whether the fet isn't shorted and the diode is ok.
Apr 24, 2009 | RCA P56923BL 56" Rear Projection...
Horizontal Output transistor looks like this attached to a heat sink near the Flyback transformer97bd027.jpg
Nov 28, 2008 | RCA P56923BL 56" Rear Projection...
Convergence problem
If the convergence is out on that set you most likely do not need to make an adjustment the circuit will need to be repaired. There is a stk on the convergence amp board that needs to be replaced. A good tv shop will run you somewhere between $300-$500 to do the repair
Oct 28, 2008 | RCA P56923BL 56" Rear Projection...
RCA-Churping Noise
it needs horizontal supply repaired and all will be well....
May 28, 2008 | RCA P56923BL 56" Rear Projection...
Where is the convergence control?
Unplug the set wait five minutes then try again go to menu where closed caption is............
Dec 07, 2006 | RCA P56923BL 56" Rear Projection...
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
