Question about Curtis CM32020S 32" TV
No picture and clicking sound only
When i turn the tv on, i only hear a clicking sound from the main pcb. no picture or audio
  • 1 more comment
  • Anonymous Aug 10, 2008
    how do i fix it
  • meemeeofeigh Dec 12, 2008
    I have kind of the same problem except my volume won't go up any louder
  • wootsiet Feb 16, 2009
    when I turn my tv on I hear sound no picture, please help me
    Novelist:
    Champion:
  • 236 Answers
This may be a power supply problem or a shorted horizontal output transistor shorted. The clicking sound is the power supply trying to start but can't because of the overload. Stargazer
Posted on Feb 25, 2007
The sound has gone on my TV the picture is good. I have put the volume on max and no sound. Can you help?
Be sure the internal speakers are turned on in your TV MENU. If still no audio, problem is most likely the MAIN PCB.(could also be the POWER PCB)..Make sure you have the 15 or 12VDC necessary to the MAIN to power the audio circuitry. For part# you will need the complete Model\Serial# for your unit.
Jan 03, 2015 | Televison & Video
Why cant I get tv sound
Be sure all your input cables are securely attached at both ends, make sure your internal speakers are not turned off.
Reset the TV by unplugging it for 30 seconds to 1 minute.
Also if you are using a cable/satelite box reset it by unplugging it for 30 seconds to 1 minute.
Do you have sound on another input such as DVD player.
if still no audio may have defective I/O-Main PCB
Jul 21, 2014 | Televison & Video
My 32 proscan tv has picture but no sound
First be sure your speakers have not been turned off( this is in your menu selections) then try another source such as a DVD player (this to rule out the source, also try a different input to be sure it is not the input. If still no audio most likely is the Main pcb, but possibly lack of power source from power pcb.
Jun 18, 2014 | Televison & Video
No sound on an lg 37lc7d tv?
Your main pcb could still have gotten damaged due to the defective caps. The reason you still have audio through the optical is because it is a digital signal only. It is not running through the audio amplifier on the main board. I would suspect either the main pcb or the speakers them self.
Mar 15, 2013 | LG 37LC7D 37 in. LCD HDTV
I Do have a Samsung LN32B530 model and it won't turn on the power lights are on but there is no picture and audio. I checked the capacitors and they are all ok no bloats and leaks... what would be the...
TV won't turn on not always from leak capacitors, T-con or pcb main it self can cause it.
Unplug T-con board than turn it on, if still no picture replace main board.
If not sure to replace pcb main, i suggest you to call samsung technician.
good luck.
Mar 31, 2011 | Samsung LN32A330 32 in. LCD TV
No picture or sound
Dear belladionne1,
Unplug TV from a/c outlet for 2-3 minutes...plug back in. Turn TV on; do you hear any clicking sounds (relay)?
NO: Check voltage on pin 1 of IC702. No voltage, suspect IC709 (5 volt regulator). The IC is on the PCB- Signal, part number 266P922010.
YES: Suspect Vertical IC, IC401 on deflection PCB( the one on the right. IC located towards front of board, on a heat sink, standing up.
These are the MOST common failures for your Model VS-585R.
I hope this was helpful, big IRISH.
Dec 29, 2009 | Televison & Video
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Damn TV....why doesn't it turn on when you push the power button??
Good Day, U-Fix- it;
Try this; CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB.
CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001.
Good Luck, big IRISH.
Apr 29, 2008 | Mitsubishi VS-50603 50" Rear Projection...
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Power light comes on, but no sound or picture
I had the same problem and my tv was out of warranty. I took it to a local repair shop and they told me didn't work on that brand. They said they charge $300 minimum for labor, plus parts. So probably at least $500 to fix. Since I figured we had nothing to lose my buddy and I took it to our shop at work and decided to take it apart and look for any obvious problems such as blown fuses, burned components, etc. All of the printed circuit boards are connected to what appears to be similar to a motherboard via data1.gif ribbons. We disconnected the data ribbon of each PCB to the microprocessor PCB and turned on the TV. Each time it turned back off after about 3 seconds. When we disconnected the Y-Main PCB the TV stayed on and I got the sound back, but no picture. We then disconnected the buffer PCB's from the Y-Main to ensure they were not the problem. Finally, we pulled the fuse on the Y-Main PCB and reconnected the data ribbon and the TV and sound stayed on again. I found a site that sells the Y-Main for $179 and I am deciding whether to try it or not. Any suggestions or comments would be helpful.
Dec 14, 2007 | Sanyo DP42746 42 in. Plasma Television
Curtis CM32020S 32" TV Logo
236 people viewed this question
Top Curtis Televison & Video Experts
Steve Allison
Steve Allison
bihug
bihug
Level 1 Expert
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
