Question about GPS
Magellan Maestro is stuck on the blue startup screen after I installed the Magellan maps update.
  • 2 more comments
  • kination Mar 05, 2009
    Half way uploading the map that I purchased from Magellan and my computer complained that the GPS was no longer found. I restarted the GPS but it got stuck in the blue screen (start up) screen.
  • SOS505 Mar 10, 2009
    I have the same problem . I was halfway loading/backing up files when the GPS drive disappeared from "my computer". Then it's stuck at the blue starting up screen forever. Tried to reset and power off/on a few times and it still stops at the blue screen everytime.
  • a gps guy Apr 08, 2009
    Yup I have the very same problem,,, I guess my battery on the 4250 Magellan was low, I was entering an address, and it turned off... thinking in was the battery, I wanted to go into my car and place the GPS on the cars power supply...
    Nothing,,, Blue Screen with the MAGELLAN logo
    did it all reset power off everything you can think of
    I called Magellan, and was told to send in my GPS, and for 200 whatever dollars PLUS 26 dollar shipping fee they would send me a new GPS...
    I had my GPS for just over 1 year and treated it better then my wife
    MAGELLAN... STAY AWAY FROM THEM go Garmin
  • Anonymous May 08, 2009
    Same exact issue as others have described. Only started happening after I tried to update the software on the GPS.
  • 34 Answers
Have you tried to reset the GPS, there is a small hole on the side, use a pen, push it in and wait for it to reboot. You may have to do it a couple of time, my sister in law had the same issue and I was able to get it back up and running.
Posted on Jul 16, 2009
Have a 4040 maestro magellan will not get off the magellan screen
if this just happened, and you have not tried to update it (sometimes the update causes this) then power the 4040 on and once it finished loading to the blue screen, using a paper clip, depress the reset switch on the left side and let it restart (little pinhole on the left side under the usb port)
if you need further help, just reply to this post.
bill
Jan 03, 2010 | Magellan Maestro 4040 GPS Receiver
Tip
Could not get this to work with a Magellan Maestro 3210 where the 2008-09 map...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 17, 2009 | Garmin StreetPilot C330 GPS Receiver
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
Magellan 3250 won't update
Hi, I had the same problem with my 3200. Got the update, and it bricked my unit. After 3 weeks of searching the net for solutions, all of which did not work, I called Magellan Tech Support today. Simply told them that I was updating the maps, update failed, and now the unit will not boot past the blue magellan screen with the progress bar. They asked for some information, including the email address that you used to register the product, and the serial number of the unit, as well as the map update information...which you had to register to get the unlock code. They are able to see all of this c in their tests on the unit, which of course did not work. I was then given a RA#, and account #, and was assured that I would get a pre-paid shipping label via email within 24 hours. All you have to do is pack the unit and take it to fed-ex with the label. They will fix your unit with the updated maps, and return it to you via Fed-Ex. Took no longer than 15 minutes on the phone, which beats the 3 weeks of research that did not help. Problem solved. Just call Tech Support, this is a well-known problem, and they will fix your unit and update the map. Hope this helps.
Dec 06, 2008 | Magellan Maestro 3200 GPS
Frozen maestro 4250
Yes, it is possible. Please email me the detailed steps you have taken until you got stuck. My email is kazi at hotmail dot com.
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
There is a RESET button on the bottom of the unit on the left side
Need to update the maps on the gps magellan maestro 3225
I need to update the map on my 3225 Magellan Maestro, can anyone help?
Sep 28, 2008 | Magellan Maestro 3225 Car GPS Receiver
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
GPS Logo
571 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
