HI there i was wondering if you could tell me the tools required to change a STK392-040 Original Sanyo IC and how technical you would expect to be to do it myself
  • 5,138 Answers
Can you solder ,and do you have a solder ******, also if you solder wrong connection together you will short out other parts, make sure you do not solder into another circuit.
Posted on Dec 07, 2008
Sanyo instruction manuals
Most universal remotes don't have all the functions of the original remote controls.You may be out of luck unless you can find an original remote. There are web sites that sell original remotes. Just Google TV parts stores.
Sep 07, 2014 | Televison & Video
My 27" Sanyo DS27800 when
U using the RCA AV cable Y,R,W plug into those tv video input holes wright?Tries another RCA Y,R,W AV cable,see if it work?U have tools like a soldering iron,a roll of solders,also can u do basic soldering?Tries take some alchahol clean the Yellow input hole and take the tv aparts resolders it connections joints,now the video out it should work again,if not yellow input hole might be shorted require replacing.
Jan 27, 2011 | Sanyo DS27800 27" TV
Two extension number not working
Hi, what causes extension number not working is because the IC that controls the number is damaged and it will need to be replaced.
The IC is a tiny chip located on the board of the phone. To be able to locate where the IC is inside the phone , You will need to unscrew the phone and Locate it.
But it's a little bit more tiny and technical than you expect. You might need to consult a skill personnel for assistance to help you locate the particular IC that is damaged and help you replaced.
Thanks for using fixya........
Jan 05, 2011 | Cell Phones
How do i change the front top housing on a sanyo 7050 ?? special tool required ??
http://www.ecrater.com/product.php?pid=5717980 I believe this is the tool that is required for opening Sanyo cell phone. It is called a Tri-Wing screwdriver.
Dec 14, 2009 | Sanyo SCP-7050 Cellular Phone
Red and green images surrounding the programming -
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 06, 2009 | Televison & Video
Distorted image and color separation and overlap
Jul 05, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Technics F61 error, can you please tell me what this means?
F61 is the "shorthand" for protection mode for Technics units. Either the regulator IC or the output AMP-PAC IC has failed. Expect a parts cost between $40 -$100 for the repair depending upon which IC has failed.
Dan
Jun 19, 2009 | Technics Audio Players & Recorders
Sanyo DS32224 TV blurry
Do you have the original remote for that TV set? If you do not, you will need to get one or borrow an original Sanyo remote so you can get into the set's menu and go to puicture set up and try adjusting the constrast up a little bit.
Mar 20, 2008 | Televison & Video
3d look on mitsubishi ws-55511
The switch is definately the way to go. I use the the 150 exclusively. Make sure you replace both IC's and for burned resistors around the IC's. Also look around the ic's to make sure all solder connections are good.
Feb 10, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Sayno Tv
You didn"t say already working in AV mode or not. Suppose if it is worked means this is the simple one just change programme (-) button in TV front panel till becomes 1 or 0. After 1 or 0 again you press down the same button you get AV mode. Even you won"t get try in menu features to change AV mode. Even you won"t get there is a problem in Micom section. Technical persons only sort out your problem by changing EEPROM ic. I hope the above information is useful to you.
Sep 02, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
