Question about HP Compaq Evo Notebook N1020v PC Notebook
Screen display The screen on mine dims and sometimes is normal bright. Moving it around sometimes I can find a position that will give me a normal screen. Any suggestions?
    President:
  • 2,961 Answers
If the power saving settings on the screen brightness is ok, then the backlight on the screen maybe on it's way out.
Posted on Feb 20, 2007
Iphone 4s sometimes when I turn it on it's dim?
You have to go to Settings>Brightness and Wallpaper and then set Auto-Brightness to OFF.Then select the appropriate brightness that you want from the brightness slider bar.
Mar 19, 2013 | Apple iPhone4 4G iPhone 4
HP Envy display stays dimmed after waking from sleep mode
Hi, i made several searches on google for you problem but did't get a right answer except this link. They provide support for HP Envy Laptop. Why not you try to call them on +1 (844) 355-5111 toll-free number.
Jul 20, 2017 | HP Computers & Internet
IPOD CANNOT DISPLAY LIGHTING
It is possible your player works correctly but some display setting causes no lighting. Try this procedure to set the screen brightness:
Choose Settings > General > Brightness, and then use the Click Wheel to move the
slider. Moving it to the left dims the screen; moving it to the right increases the screen
brightness.
I hope your problem was this only, if not I am sorry.
gylacz
Feb 24, 2011 | Apple iPod nano
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
Gateway 900g monitor will not turn on. When the power button is pushed, the blue light just flashes.
Check the monitor with a known-good cable. Look for bent pins in the connector to be safe. Next, have a bright flashlight handy. Dim or turn off the lights in the room. Turn on the flashlight and hold it very close to the screen. Look around the screen carefully and try to see a dim image in the display--if you can see the computer image, it means a problem exists with either the power supply section or, the actual display section. What is happening in this case is two(2) extemely thin, very bright, fluorescent tubes are failing to ignite. These tubes are usually laid top and bottom on the larger monitors, out of view by the user. Their light is transmitted through a series of specially designed plastic sheets which reflect against a shiny back sheet--this gives you the crisp, bright whites and colors in the image. Warning: if repairable, this is a very involved repair. Have purchasing a new monitor in the back of your mind if you send the unit out to a repair facility for a quote.--Just my thoughts--Rick
Sep 21, 2009 | Computers & Internet
Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Sep 17, 2009 | Delphi XpressRC XM Satellite Radio...
Display dims when connected to external power
mine had same problem. If I switched it off and then back on using the switch at left upper edge the screen would then come on at normal brightness. Mine later developed other problems (freezing up) and I have since returned it for replacement.
Mar 15, 2009 | Garmin nuvi 885T GPS Receiver
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Compaq Presario R3000 dimmed LCD screen
If your inverter is good I,de say your backlight is going bad, I just replaced mine in a sony vaio and now it seams to bright.
Oct 20, 2008 | Compaq Presario Notebook
HP Compaq Evo Notebook N1020v PC Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
