Question about Frigidaire ATF6000ES Front Load Washer
New belt runs too close to drum on pully
6 yr old machine, stopped spinning, belt had fallen off. New belt appears on straight, but runs nearly off the drum pulley. It's a grooved belt, and if I move the belt in it falls off, and there is no more room to move it out. Don't see any way to adjust motor pulley or shaft. It runs in this position, but the belt runs 3/16" beyond the drum pulley on the drum side. Is this OK? It seemed to be doing fine before it fell off, but shouldn't it run in the middle of the pulley. If so, how can I adjust it?
    Genius:
  • 1,028 Answers
Adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Posted on Dec 07, 2008
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the spindle.so dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
Belt has come off from drive pully to drum wheel. when trying to refit, belt runs off drive pully when i turn drum wheel by hand. machine not that old and belt in good condition (checked it against new...
I always recommend the purchase of a new belt anyway- but you appear to have one!
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Washing Machines
I had a lot of sheets and a couple of towels in the washing machine and it eventually the load just stopped before the spin cycle(dial on sanitary mode) I drained the water and tried to drain and spin and...
Thank you for using FixYa. Does the drum of your machine appear to move freely when turned by hand? If it does with no resistance, I would say that the drive belt has either come off the motor or it has perhaps been placed under a strain with a "heavy" wet load and and snapped. The drive belt can be accessed through the panel on the rear of the machine. If the belt has simply come off, run the belt round the small pully wheel on the motor and then work it onto the large wheel on the back of rhe drum. Turning the large wheel on the back of the drum in a clockwise direction whilst guiding the belt on will make matters easier.
I hope this as helped. If so please place a Most Helpfull vote
Regards
Duncan
Mar 16, 2011 | LG WM2301HW Front Load Washer
How do i go about replaceing my washing machine belt
If your machine is a front loader, then you will need to remove the rear panel, normally this is just a screwdriver requirement. make sure you take your old belt as the supplier will require the numbers from it to ensure you get the correct size. There are many different belts. Place the belt onto motor shaft and then onto drum pully wheel as far as it will go. You then need to rotate the drum by hand to feed the belt onto the wheel. After you have done this you may need to line the belt up by moving it across the grooves on the motor spindle. to do so again move the drum pully around and at same time move belt across the motor pully groves until belt runs central on drum pully. This may seem awkward but you will be suprised how easy it really is.Also it will save you a fortune by doing this yourself
Mar 13, 2010 | Washing Machines
Drum does not pin
if the drum has a belt conneting the pully on the drum to the pully on the motor it is worth repairing you just have to replace the belt.
Feb 05, 2010 | Washing Machines
Kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Oct 17, 2009 | Kenmore Sewing Machines
Neptune MAH3000AWW Pullys dont line up
Found that the rear bearing was bad, did not want to spend big money on very old machine so just replaced it.
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Changing belt
ok hi pretty lady
ok back to dryer, belt go's around drum and tension pully at bottom then to the electric motor
Jan 20, 2008 | Dryers
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
189 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
