Question about Samsung MW6350W Microwave Oven
Where can I find part# R0813207 for Microwave Samsug Model #MW6350W? How much does it cost
  • William Miller
    William Miller May 11, 2010
    That doesn't seem to be a valid Samsung part number. Or at least not a US one.
    What type of part is it?
  • Samsung Master
  • 9,098 Answers
That part's not showing up on the parts list, so you'll have to contact the Samsung authorized part distributor directly.
They should be able to give you the part number, price and availability.
J & J International, Inc.
311 Route 46 W, Suite E
Fairfield, NJ 07004
Tel 800.627.4368
Fax 973.276.9078
Posted on Dec 13, 2008
What would it cost to replace the keypad in this model
Shawn,
To help you better, we need the brand name and model of your microwave. Typically, if you have a small counter-top microwave you would probably be better off spending your money on a new microwave.
Apr 04, 2015 | In Microwave Ovens
Kenmore microwave model 7210413500 suddenly stopped heating. What are the steps I might take to troubleshoot and diagnose the probelem. Is there another microwave that can replace this model in the s
Model nimber is blocked out for some reason. But dont try to repair a microwave unless you understand how to work with high voltages. The voltages you are dealing with here are lethal. You must discharge the capacitor before any work can be done. Generally only two parts are do most of the failures, the diodes an the large capacitor. If you do not have the proper gear to test leave it alone. The cost to repair is usually runs higher than the cost of a new microwave.
Jan 29, 2015 | Kenmore Microwave Ovens
Microwave shot off completely; I check wall plug and it is ok
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care...
Mar 19, 2011 | Samsung MW6350W Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
How much is the cost for a new Household Microwave Oven (Danby)
To replace your model of Danby.... costs around $90 bucks. To fix ur Danby if its broken.... $65/hr service charge (minimum) plus parts.... We are in the disposable society, sad... but its cheaper to throw ur microwave away unless u know the basics to fix it ... like a fuse replacement. Otherwise,.. just go out and buy a new one.
Apr 03, 2009 | Microwave Ovens
Whirlpool GH7155XHS microwave shows partial display
The display is defective and requires replacement. Unfortunately, the display is probably incorporated as a unit with the control panel and must be purchased as an entire service part. This will cost $80-$120 depending on the oven make & model. It will cost more if you have a repairer install the part.
It may be more cost effective to replace the oven. Microwave ovens are rather inexpensive these days.
Mar 06, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave works for 5 seconds
"h98" INTERNAL ICU FAILURE" main control board has failed . will cost 3/4 of the cost of the microwave itself .......... get a new microwave
Jan 22, 2009 | Microwave Ovens
Turntable Motor R0813207
Fairfield, NJ 07004
Tel 800.627.4368
Fax 973.276.9078
Dec 07, 2008 | Samsung MW6350W Microwave Oven
Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Nov 21, 2008 | GE JE1640 Microwave Oven
Samsung MW6350W Microwave Oven Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
