Question about Euro-Pro 1260DX Mechanical Sewing Machine
Pinnock I have an old pinnock sewing machine and I am tring to work out how to put the Bobbin casing , retaining collar and shuttle hook back together; any ideas?
  • 3 Answers
I also have a pinnock sewmaster, here is a link to the instruction manual, hope this helps http://www.sewon.info/downloads8888/PINNOCK-FRIDOR-SEWMASTER.pdf
Regards
Posted on Aug 31, 2009
These parts came off on the LS-2220 Brother sewing machine. How do I fix it.
Good that you included the photo...
The 2 pieces look like the hook and the retainer ring that hold the bobbin.
The piece to the left is the hook ... one to right the retainer ring. The bobbin fits into the hook.
There is a diagram below that should help.
The two black 3/4" long levers need to be twisted outward...then put the hook in ... followed by the retainer ring .... and then twist the two levers back.
Generally the two parts will only fit in a certian way to be able to successfully twist the levers back ... could be some trail and error
capture-ndcrf45py13iteczuh5ab3ob-1-0.png I tried posting another diagram but fixya would not upload it ... I will post this answer and then try to add the second diagram
Feb 09, 2018 | Brother Sewing Machines
Can you still get a manual for a pinnock 380-480 overlocker??
It looks like the manuals for Pinnock are very difficult to find unless you get an original with the machine. I was able to find a scanned manual online of a Pinnock 404. This might be the closest option. https://docs.google.com/file/d/1cVL0kANzlcEwB7slhfu_Wq0Iw7mAg6dir3KyqOrSh30xJ5aG9bgpMHtI4TCF/edit?pli=1
Aug 14, 2017 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
Winding bobbin on Pinnock Craftmatic MK11
How to wind and install the bobbin, and thread the sewing ...
? 8:42
www.youtube.com/watch?v=eaEjvpwXrYA
Feb 19, 2010 - Uploaded by lanido13 This is part #1 of the tutorial. It shows how to wind the bobbin. Please check out part #2 of this tutorial for ...
Pinnock sewing machine instructions 'Sewing Machines
www.offou.com/pinnock-sewing-machine-instructions-sewing-machines...
I have picked up a Pinnock Majestic Craftmatic MK11 Model HZ-140 and I am ...Machine - Setting the Needle and Awl - Threading the Machine & Bobbin.
Oct 03, 2015 | Sewing Machines
Where do you put in the oil on a Pinnock model 450 sewing machine?
Someone was kind enough to attach the user manual to their blog. Otherwise, it would be difficult to find:
http://tailororfailure.blogspot.com/2013/04/pinnock-sewing-machine-user-manual.html
Nov 08, 2014 | Sewing Machines
Pinnock sewing machine manual
I check for one & couldn't find one, so I'll send you too
these sites,, so you can email & ask them about a manual
http://www.a1sewingmachine.com/
http://sewvacdoctor.com/
Sep 09, 2012 | Sewing Machines
I took out the bobbin case and then the shuttle race. Now I can't remember which one I should put back in first.
Clean the shuttle area, the hook and the cover with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Place the hook back in the raceway and replace the cover. Snap the two retaining levers back to hold the cover in place.
Jun 02, 2011 | White Sewing Sewing Machines
Can't reassemble the shuttle/hook in Singer sewing machine - it is Model # 1120 - an inexpensive machine but works great. It jammed and I released the retaining clamps (?) and the other little parts fell...
Turn the hand wheel until the hook race is in the left position..replace the hook to right side...replace the hook race cover..smooth end to the bottom..and snap back the hook retaining arms...now ready for inserting bobbin case...Good Luck
May 29, 2009 | Singer 1120 Mechanical Sewing Machine
Janome sewing machine
The red plastic is a device to assist clearing lint build up and is not critical for the operation of the shuttle (esp if you perform normal housekeeping and clean this area regularly, as you should)
Check there is no damage to the surface of the red plastic, as this will cause problems if not smooth (jamming)
It fits between the fixed half moon metal shuttle and the outer body.
There is a small notch which locates it into position.
Tilt the machine back 30 - 45 degrees to make the insertion easier, then fit the hook then the collar....flick the retaining clips to secure.
I always find this easiest with the machine tilted back......reduces the chances of bits falling out while you put the next piece in.
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
The finished assembly looks like this: 3fe6ddb.jpg
Mar 08, 2008 | Sewing Machines
Euro-Pro 1260DX Mechanical Sewing Machine Logo
925 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
