Question about IBM ThinkPad 600E 2645 Notebook
IBM 600E 2645 won't boot from CD rom
The hard drive was reformatted but now it won't recognize the cd rom drive. I need to reinstall Win 98 but can't at this point. Got any suggestions?
  • 1 more comment
  • meetooo112 Dec 07, 2008
    i can not open my pc with my password ?
  • jeannie0506 Dec 08, 2008
    I changed the CMOS battery. now it recognizes the CD rom. now for anthoer issue...
    during installation of Windows XP Home the setup stopped. Error message is:
    STOP 0x000000E0 (0x000000001,0x80000003, 0x00008080, 0x80DB9000).
    tried to reload windows but can't. at a stand still. any suggestions?
  • meetooo112 Dec 09, 2008
    I CAN NOT OPEN MY PC WITH MY PASSWORD
  • IBM Master
  • 32,281 Answers
You can go into the BIOS and change the boot order of the drive devices,change the CD as the 1st boot device.
OR
As the laptop boots up, press F12, this will allow you to select the CD as a boot device.
Posted on Dec 08, 2008
  • Chris Hingee
    Chris Hingee Dec 08, 2008
    You can also insert a floppy Win 98 boot disk boot up with this disk and select startup with CD ROM driver.
  • Chris Hingee
    Did you reconfigure your BIOS settings after you inserted a new battery?
    Check the BIOS settings, make sure the hard disk is set on Auto (detect), or reset the BIOS back to the default settings.
    Install XP home from the CD again from the begining.
    This time, delete the hard disk partition, then create a new partition. When it asks to format the hard disk, do a full NTFS format (not a quick format). You should be able complete your XP install.
    You may also need the device drivers for all your components (ie. video, audio, LAN adapter, modem etc.) that are installed on your laptop, if Window didn't install because it does not have them. These should be on your recovery CD, if not you need to download them from the manufacturer's WEB site.
It has win.2000 on it but wont boot up. it gets to config 32 and says its corrupt or missing. i just got it like this and have tried everything in the f8 menu, i have a xp original disk actually several...
You might have multiple problems. Are you sure the CD-Rom works? It is not uncommon for CD-ROM drives to go bad in laptops. If it was bad before and then the hard drive became corrupt all before it was given to you then you would have no way of knowing. This would explain why you do not get the Press Any Key to Boot From CD on boot.
There is no doubt that the hard drive image is corrupt, so the first thing I would check is the CD drive and go from there.
Jun 15, 2009 | IBM ThinkPad 600E 2645 Notebook
Formatting IBM Thinkpad 600E
I know you can't boot from the Windows 98 CD, and probably not from Windows 2000 either. It is possible to turn the the Windows 98 bootable floppy into a bootable CD, but I think you would be much better of trying to install Linux.
Mar 16, 2009 | IBM ThinkPad 600E 2645 Notebook
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Screen
Probably the display driver is messed up. Best option is to reinstall the operating system.
An alternative is to have a Linux-savvy friend try to boot it up
with a Linux-live rescue CD to see if that fixes the display problem and maybe to salvage your personal data from the hard drive.
Feb 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Ibm thinkpad 2645 600e
if you got a windows xp cd then boot from it and format the drive then reinstall xp
Dec 09, 2008 | IBM ThinkPad 600E 2645 Notebook
600E 2645 won't boot from cd rom
u will have to go to your setup screen and reorder your boot screen so your cd rom will boot first so you can install windows 98, but if your cd rom isn't working you need to go to your device manager and look for your cd rom and install the driver
Dec 07, 2008 | IBM ThinkPad 600E 2645 Notebook
I have a 600E that had the hard drive reformatted. I don't have a boot disk for the system (only has CD drive) but it won't boot from that when I try to reinstall Win 98. Got any suggestions?
Your cpu is slower than I was thinking of. However you should be able to load XP. When you load XP remove all partitions and set it up on NTFS. Go for a full installation, load, anti virus and any utilities that you want. Get yourself an external hard drive and save all your folders to that after you have finished working on them. That way you will free up your cpu to manage. If you still want to load 98. Try going into the Bios and set the CD drive as your first boot option, with a bit of luck it may work. Once you have loaded your operating system be it 98 or XP, go back into the bios and re-set your boot preferences to HDD then CD Rom. Failing that I can not help you any futher. You may think of up grading to at least a P3 in the future. Another point. Borrow a copy of windows XP from a friend and install that, if it loads ok then you can obtain your own copy if you want to.
Dec 07, 2008 | IBM ThinkPad 600X Notebook
Windows 98 reformat to windows 2000 SP2?
i think it is not possible to install windows 2000 sp2 on your machine,becoz the configurations is not suitable for windows2000 sp2.You may try some other os to boot.
Aug 23, 2008 | IBM ThinkPad 600E 2645 Notebook
Unit will not boot from cd/dvd, drive test good.
The main programing on the motherboard (bios) should recognize and read from the CD drive, If it doesn't then there is three possibilities as to the problem. 1- the bios have glitched, so, start by doing a bios flash. 2- the optical eye or the reader board in the CD drive has gone out, and the drive will need replaced, 3- there is a malfunction with the motherboard, and the board will need to be replaced. These three are the only possibilities and fixes for this problem.
Jul 26, 2008 | IBM ThinkPad 600E 2645 Notebook
UPGRADING
That unit it about 10 years old.
Unfortunately, you cannot upgrade the CPU (processor)
The RAM is a standard 100MHz non-parity SDRAM SODIMM. The 2645 can use 128MB DIMMS for 160MB maximum. It has 32MB internal and two slots.
The hard drive size is limited by the BIOS. Any standard 2.5" hard drive should work, but may show as limited size, maybe 20GB.
Get a PCMCIA modem.
If you found a docking station for this unit, you'd be in better shape. Like I said, it's 10 years old. It won't be easy.
Jul 22, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
1,606 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
