Question about Fanner MASSCOOL 3.5" PATA and SATA hard drive media player MP-1368AS-Retail MP3 Player
Files missing I can see files when Masscool device connected to computer but not when connected to TV. It had been working find until I added more files. Why?
  • Jrafaelz Mar 06, 2009
    Tengo un disco IDE de 80GB Western Digital conectado Masscool MP-1368AS 3.5 Puedo ver los archivos de musica "40GB aproximadamente" cuando el dispositivo esta conectado al ordenador, pero cuando se conecta a la TV solo se ve una carpeta con pocas canciones. Se ha estado trabajando hasta encontrar he añadido más archivos.
    ¿Por qué?
  • Anonymous Mar 29, 2009
    I have the same problem. I can see add/delete/see files when connected to my computer, but can not see files when connected to my tv
Mines wont appear on anything but it shows signs of life?
dominique_tavares@rocketmail.com
Posted on Oct 20, 2012
  • 4 Answers
Copy the files from another computer, The same thing happened to me, and that solved the problem.
jack
Posted on Aug 13, 2009
  • jacinto wesly Sep 17, 2009
    The other solution is to format to Fat32. I used the easeus partition software. This solution has worked all the time, but you would have to go back to fat32
    jack
On my tv the pc hdmi under the setup has a circle with a line through it . I need to connect my tv with hp stream notebook. I have not been using this tv so the setting and cable are not connected
what are you trying to do..? end goal.
my guess is HPside , is missing the correct HDMI divers
one can say play netfix on PC and push it up to TV
one can use pC as a sources of files, a file server
and the TV sees them and can play those media files
2 ways, off top of head.
this does not compute (cant work like that)
I have not been using this tv, so the setting and cable are not connected.
Feb 09, 2017 | HP Computers & Internet
System files are missing
How to recover system files on H10?1.4_4_2012_7_54_27_am.jpg2. LCD on H10 displays "USB Connected" and then double click "My computer".
3. Click right mouse on "H10" drive and select "Properties"
4_4_2012_7_55_46_am.gif4. Go to Tools -> Error checking -> Check Now -> Check "Automatically fix file system errors" and click start.
4_4_2012_7_56_53_am.gif5. It will take you around 1~2 minutes, 5 minutes at maximum.
4_4_2012_7_57_35_am.gif6. Go to "Tools -> Folder Options -> View" on Windows Explorer. Uncheck "Hide protected operating system files(recommended)". Click OK to save properties.
4_4_2012_7_58_37_am.gif4_4_2012_7_59_08_am.gif7. Double click on "H10 drive" and delete "System" folder.
8. Open iriverplus and transfer music.
If your device was detecting by USB cable. Then update the firmware for this device:
1. Please open iriverplus3 and connect your device with USB cable.
2. After connecting your device, please follow the steps below to upgrade New Firmware
** Tools -> Portable Device -> Firmware Upgrade **
3. After upgrading the New Firmware, please check the firmware version before playing device.
** Setting -> Advanced -> System information **
Hope this will resolve the issue.
Regards
Nandu
Apr 04, 2012 | iRiver H10 MP3 Player
My computer is missing important system files
> type the path ...
Specify: C:\WINDOWS\ServicePackFiles\i386
as the "path".
Jun 23, 2010 | Computers & Internet
Windows vista wont load
Hi I believe that wouldn't be a problem. If you want to do a system recovery, the laptop usually comes with a back up partition where all the files to do system recovery is stored. You can use these files to restore the setting back to the point when you first purchased the item.
REMEMBER: All your datas will be erased when you do the System Recovery.
For me guide you on have to access the files, I need the make and model of your laptop.
NOTE: If the RECOVERY or FACTORY_IMAGE partitions on the hard drive have been deleted OR the files in these partitions have been deleted, these steps will not work. You must use recovery discs.
  1. Turn off the computer.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer and immediately press the F11 key repeatedly , about once every second, until Recovery Manager opens.
  4. Click Next .
    A Microsoft System Restore screen opens.
  5. Select No, I would like to see other options , and then click Next .
    A System recovery screen opens.
  6. Click Yes , and Next to continue the recovery process.
    The Recovery Manager gives you the option of backing up your data files. To do so, read Backing up your files .
  7. To continue recovery, select No , and then click Next .
    A recovery progress screen opens. Wait while files are restored.
  8. When System Recovery is complete, click Finish
  9. The computer restarts and continues into Windows setup.
  10. Complete the setup screens and wait until the computer finishes the setup.
  11. Turn off the computer, reconnect all peripheral devices, and turn on the computer.
  12. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  13. Reinstall any software applications that were added after purchasing the computer, and replace any files that were backed up.
Please rate this solution.
Jan 14, 2009 | Computers & Internet
Added music, but can't listen
I experienced a similar problem caused by corrupt files saved on the internal memory of my e280.
(I could not delete/remove the files) I had to format the internal drive of the e280
and re-copy the files back on to the unit. Works great now. When formatting the device
use the command from windows. (ie right click on the internal memory icon and select format)
Note: Formatting will remove/delete all the files (eg music,photos..) from the e280 so make sure that
you have backups.
Cheers
Nov 30, 2008 | SanDisk Sansa E280 MP3 Player
Doing siytem restore,and have no operating system.Vista home premium model no s 3460 sofware build 82APv3PrA1.Im under warranty what can i do?.In the start of system restore computer stopped,message reeds...
Starting the recovery from power up If Windows Vista cannot open and if the Recovery partition on the hard disk drive is functioning properly, you can perform a System Recovery by performing the following procedure:
  3. Turn on the computer.
  4. Do one of the following actions depending on how Windows Vista was installed:
    • If Windows Vista came pre-installed on your computer, press the F11 key repeatedly when the first screen opens (the logo screen), until Recovery Manager program opens on the screen.
    • If your computer was upgraded from Windows XP to Windows Vista, press the F10 key repeatedly when the first screen opens (the logo screen) until Recovery Manager program opens on the screen.
    If Recovery Manager does not open, a set of recovery discs is needed to perform a System Recovery. Follow the instructions listed in Starting the recovery from recovery discs .
  5. Click Next .
  6. On the screen that prompts for Microsoft System Restore select No , and then click Next .
  7. The Recovery Manager gives you the option of backing up your data files. Backing up your files is recommended. To back up your files select Yes , and then click Next . Follow the onscreen instructions. If you do not want to backup your files, select No , and then click Next .
  8. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup. Then, turn off the computer, reconnect all peripheral devices, and turn on the computer.
  9. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  10. Reinstall any software applications that were added after puchasing the computer, and replace any files that were backed up.
Nov 06, 2008 | HP Computers & Internet
IRIVER H10 system files misssing
you can just go into the shop you bought it from or dicksmiths or something and they would sell the disc
as for your computer one just plug in your device then when you think it has loaded and everything go in to my computer and it should have your device there!
Oct 12, 2008 | iRiver H10 MP3 Player
Ext WD500GB drive not being recognised by my computer,but seen in device manager
try downloading this and and scan may be it might locate yr drive since windows can still see it in device manager. and with these u can recover even deleted and formated files. try it
http://services.seagate.com its trial version so u can get a full version n pay little or find similar software but i know yr drive can still work fine its just that we r missing something here.
thank u
May 27, 2008 | Computers & Internet
ARCHOS Bluescreen of death
I have this same problem. I am able to get to a point where I can access my files on my computer. To do this, I connected my player to my computer. Then, I did a system recovery. To do this, turn the player on and press and hold the TV/LCD button immediately after the green light turns on until the screen turns white. This doesn't always work on the first try. If you let it go to the blue screen and then reboot it again, press and hold the TV/LCD button when the Archos logo comes on the screen. That seems to work for me. Pick the system recovery option. When I do this, the player says "connect your device to your PC and install an update file." At this time the computer recognizes the device and I can get to my files. That is as far as I can get right now. When I try to install an update file, I end up getting the message "update failed (code 207). And I have to restart the process all over again. I hope this makes sense. I'll let you know if I ever can get any further with this.
May 16, 2008 | Archos 605 WiFi Digital Media Player
Thomson Lyra Jukebox pdp2860 av system files problem
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
Jul 23, 2007 | Thomson Lyra PDP2860 Digital Media Player
Fanner MASSCOOL 3.5" PATA and SATA hard drive media player MP-1368AS-Retail MP3 Player Logo
197 people viewed this question
Top Fanner Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fanner Audio Player and Recorder Expert? Answer questions, earn points and help others
