Sun Aire Sun-Aire Air Purifier - Stainless Steel, Permanent Filter for areas up to 2,000 Sq Feet Air Purifier
Problem for Sun Aire Sun-Aire Air Purifier - Stainless Steel,...
What room sizes can an air purifier clean?
By Joey2 - usenet poster
Same Problem
Apr 09, 2009
-   Do I have to put water in the air purifier like the humidifier kenmore 83250 -   Bertica
Best Solution
posted on Dec 27, 2007
Very Helpful)
ekwade
Rank: Apprentice
Rating: 87%, 3 votes
If we are talking about an EcoQuest Fresh Air purifier, they are rated at handling up to 3000 square feet of actual air-space (not to be confused with wall-to-wall size). This means, the less space is available for the air to occupy (empty house -vs- full house) then the larger space can be accommodated.
Remember, a Fresh Air is designed to be a "whole home" purifier unit, because it does not need to pull the air through the machine to clean it.
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Somewhat Helpful)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
The performance of all air purifiers is rated AHAM. Look for the AHAM seal on the packaging for room size information. Most air cleaners also have appropriate room size reference on the front of the packaging. All room size recommendations are based on AHAM test results. They can vary from 6? x 9? to 20? x 24?.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Oct 30, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Yes, purifiers participate in the AHAM's CADR testing will calculate their suggested room size based on the testing results.  However, some purifiers do not participate in the CADR testing and their suggested floor space calculations are all over the map (very inconsistent).  There is no legal guideline for floor space calculation, thus it is much safer to go with the CADR ratings.
Solution #4
posted on Aug 09, 2007
Not Rated)
SUN AIRE
Rank: Master
Rating: 98%, 11 votes
The SUN AIRE purifier comes in two sizes; the 11" X 10" X 8" SUN AIRE purifier with handle built of brushed stainless steel and weighing only 9 lbs. covers up to 2,000 sq. ft. The large commercial size which measures 33" X 14" X 7" and can either be wall-mounted or with a handle- also stainless steel inside and out- covers 4,000+ sq. ft. They are NOT just a one room air filter, but a whole-house point of contact indoor air purifier.
Was this helpful?
Yes
No
Popular Solutions for Sun Aire Sun-Aire Air Purifier
Questions and Unsolved Problems for Sun Aire Sun-Aire Air Purifier
Do you recommend Sun Aire Sun-Aire Air Purifier - Stainless Steel, Permanent Filter for areas up to 2,000 Sq Feet Air Purifier?
Answer
Answer
hOW DO YOU CLEAN FILTER?
Answer
My ionic breeze g.p. has a burned out bulb, and no power lights come on. Is this because of the bulb... (More)
Answer
My Amcor Group Air Treatment System 120 needs new filters, how can I obtain them
Answer
i have a ionic breeze that i bought two for one at bed bath and beyond. the switch does not turn it... (More)
Answer
i was cleaning my Alpine XL15 air purifier, and I accidentally unplugged the power switch. which... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifier Experts
Top Air Conditioner Repairmen
in , HI
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
