Question about IBM ThinkPad 600E 2645 Notebook
600E 2645 won't boot from cd rom
The hard drive was reformatted. now it will not boot from the CD Rom. I want to reinstall Windows 98 but at this point I am at a stand still. I am trying to use the system as it is without having to replace anything on it. I know of the site to get the missing software for the system I just can't get it to recognize the CD rom drive. Thanks
  • jeannie0506 Dec 09, 2008
    there isn't an OS loaded on this system. I need to reset the bios (installed a new CMOS battery) but I don't know how to get into the bios. I don't have the options or don't know how to get into them at this point. I have downloaded a program that will reset the bios, yet I can't get to a dos c: prompt to use the program to hopefully correct the errors. Any suggestions?
    Sergeant:
  • 302 Answers
U will have to go to your setup screen and reorder your boot screen so your cd rom will boot first so you can install windows 98, but if your cd rom isn't working you need to go to your device manager and look for your cd rom and install the driver
Posted on Dec 07, 2008
How do i reformat my pc?
This is a pretty drastic process and takes several hours. If you have system slow downs and ongoing bugs you may be able to repair with software tools (see here), however that said, on with the show.
The procedure will decimate the data on your C: drive, so it's crucial that you back up all the data you don't want to lose.
Don't forget items like e-mail data and address books (see: How to backup e-mail.). Back up all your documents including your "My Documents" folder and all the data you've stored on your Windows Desktop which you'll find in c:\Windows\Desktop or c:\Windows\Profiles\<yourname>\desktop, where <yourname> is your Windows log-on.
Don't worry about backing up programs that you can reinstall later, unless you want a complete backup of your C: drive in the event of a problem.
Now, create a boot disk. Creating a Windows 98 boot disk is easy. If Windows 98 came factory-installed with your machine then one may have been supplied with your documentation. If not, you can create one through the Control Panel. In Windows, go to Add/Remove Programs and click the "StartUp Disk" tab and click the "Create Disk" button. It will create a boot disk on a blank floppy for you with CD-ROM support.
This is important, as you'll need access to your CD-ROM drive to do a new Windows98 install.
Once the boot disk is created, test it to see if you can access your CD-ROM drive. To do this reboot the machine with the floppy disk in the floppy drive and when the machine restarts choose "Start with CD-ROM support".
At the prompt type d: and hit the Enter key. If the machine responds with D:\> you are in business.
Next type "format c:" without the quotes (and hit ENTER).
The C: drive (main hard drive) will then be wiped clean.
Once the reformat is finished put your Windows CD-ROM disk in the CD-ROM drive, and type "D:\setup" at the prompt.
Once Windows is finished installing, reinstall your backup software and restore your data to the hard drive.
And Thanks.
Mar 05, 2010 | Microsoft Windows 98 for PC
It has win.2000 on it but wont boot up. it gets to config 32 and says its corrupt or missing. i just got it like this and have tried everything in the f8 menu, i have a xp original disk actually several...
You might have multiple problems. Are you sure the CD-Rom works? It is not uncommon for CD-ROM drives to go bad in laptops. If it was bad before and then the hard drive became corrupt all before it was given to you then you would have no way of knowing. This would explain why you do not get the Press Any Key to Boot From CD on boot.
There is no doubt that the hard drive image is corrupt, so the first thing I would check is the CD drive and go from there.
Jun 15, 2009 | IBM ThinkPad 600E 2645 Notebook
Formatting IBM Thinkpad 600E
I know you can't boot from the Windows 98 CD, and probably not from Windows 2000 either. It is possible to turn the the Windows 98 bootable floppy into a bootable CD, but I think you would be much better of trying to install Linux.
Mar 16, 2009 | IBM ThinkPad 600E 2645 Notebook
Screen
Probably the display driver is messed up. Best option is to reinstall the operating system.
An alternative is to have a Linux-savvy friend try to boot it up
with a Linux-live rescue CD to see if that fixes the display problem and maybe to salvage your personal data from the hard drive.
Feb 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Ibm thinkpad 2645 600e
if you got a windows xp cd then boot from it and format the drive then reinstall xp
Dec 09, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM 600E 2645 won't boot from CD rom
You can go into the BIOS and change the boot order of the drive devices,change the CD as the 1st boot device.
OR
As the laptop boots up, press F12, this will allow you to select the CD as a boot device.
Dec 07, 2008 | IBM ThinkPad 600E 2645 Notebook
I have a 600E that had the hard drive reformatted. I don't have a boot disk for the system (only has CD drive) but it won't boot from that when I try to reinstall Win 98. Got any suggestions?
Your cpu is slower than I was thinking of. However you should be able to load XP. When you load XP remove all partitions and set it up on NTFS. Go for a full installation, load, anti virus and any utilities that you want. Get yourself an external hard drive and save all your folders to that after you have finished working on them. That way you will free up your cpu to manage. If you still want to load 98. Try going into the Bios and set the CD drive as your first boot option, with a bit of luck it may work. Once you have loaded your operating system be it 98 or XP, go back into the bios and re-set your boot preferences to HDD then CD Rom. Failing that I can not help you any futher. You may think of up grading to at least a P3 in the future. Another point. Borrow a copy of windows XP from a friend and install that, if it loads ok then you can obtain your own copy if you want to.
Dec 07, 2008 | IBM ThinkPad 600X Notebook
Windows 98 reformat to windows 2000 SP2?
i think it is not possible to install windows 2000 sp2 on your machine,becoz the configurations is not suitable for windows2000 sp2.You may try some other os to boot.
Aug 23, 2008 | IBM ThinkPad 600E 2645 Notebook
No Audio Driver
go to microsoft.com they have most drivers there to download
Mar 25, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
200 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
