Question about Adobe Audition 3 for PC (22011292)
I cannot switch to multitrack view
I can open Audition 3 in the edit view but if I try to switch over to the multitrack view it will freeze up my computer. If I try to open a session in multirack view from a saved session I have Audition will load but then I get a message box that says "To continue where you left off please restart Audition" I click ok and a Runtime error box opens stating "R6025-pure virtual function call. I have uninstalled and re-installed and still same thing happens when I try to go to multitrack view. Any ideas why this is happening and/or what I can do to make it stop and work correctly?
  • Anonymous Apr 04, 2009
    I can look at both edit view and cd view but the multitrack view does not open the icons and names change across the top but the screen stays the same what can I do to resolve this issue I can't even uninstall audition I'm using vista 64 bit
I have the same exact problem....same damn thing and it is so frustrating because I need to finish a song today!!!!!!
Posted on Dec 29, 2009
What is the real purpose of the adobe audition?
Adobe Audition (formerly Cool Edit Pro) is a digital audio workstation from Adobe Systems featuring both a multitrack, non-destructive mix/edit environment and a destructive-approach waveform editing view.
Adobe® Audition® software delivers the professional tools you need to make your video and audio productions sound their best. Handle a wide range of audio production tasks efficiently, including recording, mixing, and sound restoration.
What's new in Adobe Audition
au-native-mac-support-147x83.jpg Native Mac OS support Record, mix, edit, and master your audio with a powerful cross-platform audio toolset: Adobe Audition CS5.5 runs natively on Mac OS X v10.5 and v10.6 as well as Windows®.
au-roundtrip-editing-premiere-147x83.jpg Roundtrip editing with Adobe Premiere Pro Easily sweeten audio for video. Pass individual clips and multitrack mixes from Adobe Premiere® Pro CS5.5 software to Adobe Audition for editing, or send Adobe Premiere Pro sequences with a reference video to Adobe Audition for complete soundtrack creation.
au-project-exchange-147x83.jpg Project exchange with third-party NLEs and DAWs Easily move sessions between Adobe Audition and Avid Pro Tools using built-in OMF import and export functions in Adobe Audition. Share files with other video NLEs via XML interchange.
au-5.1-support-147x83.jpg Native 5.1 multichannel support Edit multichannel files and mix your projects in 5.1 surround. Adobe Audition CS5.5 includes a Surround Panner in the Mixer View, as well as a new Surround Reverb effect and Amplify, a multichannel gain processor.
Aug 17, 2011 | Adobe Computers & Internet
In have an new HP and instulled Audio Audition 1.5 while in multitrack view and am trying to record, I get a "Device ID out of range message" I've tried mostly everything.
Wow, it sounds like you didn't set up a device in the mixer for stereo input, or Adobe deadpanned that you wanted to record mic in and didn't ask to fix that going into multitrack. I've seen that often enough teleconferencing from WinXP swapping audio devices in and out, but by Windows 7 and 2011...this is a surprise. Just activate the appropriate line in in the input mixer in Windows (or more likely, your multitrack input mixer's controls.)
Surely this isn't it, and Adobe wants you to walk through the input level test modules first?
Mar 13, 2011 | Adobe Audition 3 for PC (22011292)
Hi, I can't seem to access the multitrack view on Adobe Audition. Every time I want to open a session file, it says to restart Adobe Audition. I have tried restarting my computer several times but it...
Did you check the logs? Rightclick stuff in the organizer window to send them to the multitrack, then name the tracks in multitrack if you can get it to open...or maybe your DDR2's falling out from all the bass?
Oct 26, 2010 | Adobe Audition 3 for PC (22011292)
No sound in waveform editing in Adobe Audition 1.5
try uninstalling and then reinstalling back Adobe Audition 1.5 or try out Adobe Audition 3
Feb 10, 2010 | Adobe Audition 1.5
No sound in edit view
Well, the settings in edit view and mutitrack view are not, unfortunately, the same... you can set them the same, but it's not that way by default.
I haven't used 1.5 in a while, but my initial guess is that one of these are true:
  1. You've muted audio play-back on the edit view
  2. You've disabled monitoring on edit view
  3. The playback source in edit view is set to the wrong hardware.
  4. I believe there was a playback volume controle even in 1.5.  If so, you could have actually turned the volume all the way down for playback..
If I get a chance later this afternoon, I might try reinstalling 1.5 and seeing if I can get figure it out on that version.
Post back with your results so far.
Also, it'll be helpful to know what version of Windows you're using.  In Windows Vista, there's a volume mixer where you can control the volume for any open applications as well as Windows sounds - different than the typical mixer setup in XP and prior.
Jan 06, 2009 | Adobe Audition 1.5
Echo problem in adobe audition 1.5 (not environmental)
My best guess to start with is a reverb setting of some sort.
Are you recording in multitrack or edit view?  If one, try the other, and see if you get the same results.
Another guess would be a sound-card setting.  If you have any special effects setup on your soundcard (onboard, pci, pci-express, usb, etc), that could cause it.  Things such as 3d-surround settings, environmental settings, etc..
Also, what version of Windows?  What sound card/ audio interface?
Jan 05, 2009 | Adobe Audition 1.5
I cant record nor play while in Multitrack View, i can only play while in edit view ...? This is for adobe audition 1.5 ? Anyone know whats going on ???
Need more detail: 1. What sound card are you using?  - You need to make sure the correct hardware is selected as your record and playback types.  For instance, if you have more than one sound card, you could have easily the default one setup, but you really need your recording one - such as an ASIO driver - such as for external USB mixers.
2. What version of Windows?
My best guess is the hardware setup is off.  You have to have the correct hardware setup for Audition to see it.  Wave view and Multitrack view have diferent settings, each, so you have to set them up separately.
Dec 30, 2008 | Adobe Audition 1.5
While recording through firewire solo cannot hear input but hear
  1. What version of Audition?
  2. What version of Windows - or other OS?
  3. Edit View and/or Multi-Track view issue?
  4. Are you recording in Multitrack view, then listening in Edit view?  Each has its own hardware setup..
My best guess is that one of these thigns are true:
  1. You have not enabled monitoring
  2. In multitrack view, I believe you have to send each signal to the master, and then enable monitoring for the Master... but I can't remember for sure.
Post back to let us know
Nov 24, 2008 | Adobe Audition 1.5
Don't hear audio in multitrack
One of these must be the case:
  1. You've not enabled monitoring in multitrack view.
  2. The hardware setup is not correct under multitrack view.
  3. You may have to (I forget if this was the case for sure or not) send each signal you're listening to to the Master... I'll have to look at home..
If that doesn't work, offer these clarifications, and I may can check into at home:
  1. What version of Windows or other OS?
  2. What version of Audition?
  3. What sound hardware do you have installed (more than one? - please provide specific card(s)/device(s))
Oct 22, 2008 | Adobe Audition 1.5
Can't record in multitrack
Adobe Audition 1.5
It seems your adobe audition 1.5 is missing file / files or adobe's registry has gone corrupt. If you ever run registry cleaners or registry fix some of them corrupt the registry of this adobe audition 1.5 try Reinstalling the Program and it should work. This Program is very Reliable and shoud have no problems with it. I use it all the time to download from internet and then edit to my requirement. I hope this helps. If you still have problems try to down load trial software from www.adobe.com Adobe audition 2.0 is free for download to try.
Good Luck
Jan 17, 2008 | Adobe Audition 1.5
Adobe Audition 3 for PC (22011292) Logo
667 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
