Question about Hotpoint WMA58 Front Load Washer
Blockage Can anybody please help? i have lost my mannel for my machine and think i may of got a blockage in my drain hose/pump. The main problem is i don`t know where that is. I took of the pannel off the very bottom of the machine (front) just to find a sliver strip. thanks
  • adele cornwall Feb 18, 2007
    Dear A, you were right I have found the pipe and was unable to block the pipe. thanks once again Delie
  • 247 Answers
You're quite unlikely to have blocked your drain hose, although you could have kinked it (so check for this first). Failing that, common blockage sites are in the pump chamber, and in the hose connecting the pump to the bottom of the drum - particularly where that is pushed onto the pump. You may also find blockages in the outlet from the drum. It is a pain when manufacturers don't bring the pump out onto the front panel. Best bet is probably to tip the machine backwards against a wall and see if you can get access through the underside. Failing that, remove the back panel and go in that way. Just follow the drain hose, and you'll find the pump. Before you start taking it apart, make sure the power is off, and be prepared for there to be quite a lot of water hiding in that corner of the machine. A.
Posted on Feb 17, 2007
Washing machine not draining water
Hi.
Disconnect power, then move the machine forward and check the drain hose at the back of the machine. Check if the hose is kinked or blocked and check that the hose height setting is as from manual. If the hose elbow is set at incorrect height the water will be siphoned back inside the tub.
Access the drain pump filter (this is located behind front-bottom access trim or door ). If there is blockage in there the water will not be drain completely. Remove trim, unscrew the cap and be prepared to collect water. Ensure that power is off. Remove any blockage in there.
lean or replace the pressure switch and the rubber hose connected to the pressure switch. This device detects water level and stops drain when there is no more water.
If all that does not help, then the drain pump itself must be tested. In some rare case the main control module may be defective. Test all the rest first.
The problem is usually given by blockage, drain hose or by pressure switch.
Regards.
Ginko
Apr 28, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a kenmore elite not draining cleaned out by pump no blockage pump bad
Remove the lower panel and put the machine in a spin mode and see if the drain pump sounds like it is working. You may have to remove the hose from the pump to the bottom of the main drum. You could have a sock or something small get around the spin tub and make its way to the hose going to the pump and blocking it. Also check to make sure there are no crimps in the drain hose going from the pump to the main drain.
If every think is clear and there is power going to the pump and still not working, replace the drain pump and motor assembly.
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine will not drain
hi there.......the blockage is in the pump housing at the impeller....this will require removing the pump seperating it to remove the blockage...but first..check that the main hose from the tub to the pump is not blocked....
regards Sir Galahad
Aug 18, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Does not drain
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
May 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Will not drain
May 04, 2009 | Splendide 2000S Vented Washer/Dryer
Washer not draining , the pump has been replaced and its still not draining , drained water hose in bucket, no blockage, is it the relay?
Apr 06, 2009 | Hoover HF7 160E Front Load Washer
Washer will not drain
Mar 23, 2009 | GE WSM2780W Stacked Washer / Dryer
Jan 02, 2009 | Frigidaire FWS833A Top Load Washer
Water not draining from machine
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
82 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
