Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
Handle will not stay open
When I turn on the hot water part way, the handle just fall to the closed position. It will not stay open unless fully opened. How do I correct the situation?
  • bjork90 Apr 15, 2009
    Same problem here. Happens sporadically and is difficult to recreate. Water pressure seems fine.
    Scholar:
  • 44 Answers
The reason behind this is because when its part opened theres not enough pressure to keep it open, but when you open it highre it stays open, another reason could be due to the water outlet strainer being blocked, remove this & give it a clean out & see how it goes?
Kindly
Richie
Posted on Dec 15, 2008
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
Low water pressure from moen shower faucet
I'm slightly in the dark on this because I have no idea which model moen shower valve do you have? Here's a shot in the dark....single lever anti-scald tub and shower valves, moen brand in fact, prevent scalding by a means of a cog or two, (a cog is a flat metal piece, with an arm sticking out on a 90 degree angle, and has a star shaped cut out in it's center. That star shaped cut out fits perfectly over and on to the center stem of the valve. These cogs are located under the handle. These two cogs are what limit the handle from opening completely counter clockwise. When the handle is at it's most open counter clockwise position....the port that allows hot water to enter the valve and come out of the shower head is at it most open position. Those two cogs are what prevents the hot port from being fully open by means of the 90 degree arms sticking out and under the handle. The handle has two flat surfaced walls that catch on those arms sticking out from those cogs under the handle. You have to position the cogs on the spindle, (valve stem), in a position that will stop the handle short of full counter clockwise to prevent the shower valve from opening enough to allow enough hot water to pass through the port to possibly scald a person while showering. It's a real tricky process setting those cogs to a position so that when your valve stops it's counter clockwise rotation, (which is how the valve it turned on), it stops in a position that only allows enough hot water to flow that mixes to be a nice warm shower water temperature. You see, with the hot water flow limited, there is little chance you will ever be burned by your shower water (thus...anti scald mode is in operation).....
Now here's the kicker.....When soldering the connections on your shower valve, (during the installation process), the installer must remove the cartridge from the valve body to prevent melting it with his torch while soldering the joints. When that cartridge is removed, those two cogs hang loose and slide off the spline. And when they are removed, it is quite a chore to place them back into the position they are intended to be placed in. and..WHEN THE COGS ARE RE-PLACED IN A CERTAIN (WRONG)POSITION, IT FORCES THE HANDLE IN A POSITION THAT IS WRONG, AND WON'T ALLOW THE HANDLE TO REST IN THE OFF POSITION. The cog arms are preventing the handle from rotating to a completely closed position. Which causes exactly what I think you are experiencing. When the main water valve is turned back on....you can't stop the water from flowing through your newly installed shower valve. Those cogs...in the wrong position on the spline....will not allow the handle to spin to the correct point of the off position.
You have to remove your handle, slide the two cogs off of the spline, then re-place the handle on the spline and turn it until the water stops flowing out of the shower head....now pull the handle back off....look at the underside of the handle....you will see a couple of walls within the open underside. those walls are what the arms on the cogs hit to stop the rotation of the handle....Now hold your handle in front of yourself and face the shower valve....now position the lever on the handle straight down....now lean the handle back to view the positions of those two walls on the underside of the handle.....now imagine those two arms on the cogs sticking out in the area between those to walls ....with one arm positioned to stop the handle in the position with the lever straight down....then imagine the other arm sticking out in a position somewhere around 11 o'clock, (if you look at it like a clock), .....so now the first arm is around 6 o'clock and the other at 11.....now slide the handle onto the spline, with the lever down .....then test the valve by turning counter clockwise to turn it on. ....turn it until it is stopped by the cog arm....now feel your water temperature....if it's good...then turn the handle clockwise to the off position....is it all the way off? if not, pull the handle off...adjust the 6 o'clock cog arm back toward the 7 o'clock position, just one spline ....replace the handle and try again.....that should fix the off position....if you need the water a little warmer, move the 11 o'clock cog arm toward the 10 o'clock position a position or two....to get a cooler mix on your water....move the 11 o'clock arm the opposite direction.... WHEN YOU HAVE FINISHED RE-CALIBRATING THE VALVE....SECURE THE HANDLE AND COVER BUTTON BACK IN PLACE AND CALL IT GOOD...IF YOU DIDN'T DROP THE HANDLE SCREW OR ONE OF THE COGS DOWN THE DRAIN......OOPS...SHOULD HAVE MENTIONED TO PLACE A TOWEL OVER THE DRAIN WHEN YOU DIS-ASSEMBLE YOUR SHOWER VALVE...I hope your not corn fused by my lengthy instructions....and I hope you understood the terms "cog"(the two removable metallic pieces that slide on and off the center spline), -"spline"(the metallic stem sticking out of the center of the valve, it has gears all around it) -"handle lever"(the portion of the handle that protrudes outward, away from the center) -"walls on the underside of the handle"(the two flat pieces molded into the underside of the handle that act as stops by not being able to spin past the protruding arms of the cogs)...Good luck my friend and remember to always work safely....
Mar 30, 2013 | Moen 1 Handle Lever Shower Faucet With...
`hot water spout handle not fully opening
When opening the faucet if the flow is not as it used to be, there could be a couple of reasons. First the machine may not be filling correctly. Check the fill probe is clean and free of scale.
The most likely scenario is that the rubber seal within the faucet has become detached and is therefor not lifting correctly. You will need to contact your local Bunnomatic service agent to either request a repair or get the seal to fit yourself. Remember to drain water out of the boiler with the machine switched off, and ensure there is no flow from the faucet before you remove the top section of the faucet to replace the seal
bb4a0281-cb42-4d60-98d7-98e5258fd47d.jpg 66a2710c-cd82-4a2e-ab14-31eb46f75843.jpg
Jan 24, 2013 | Bunn Dual TF DBC Coffee Maker
The lever that turns the water on doesn't stay up. Can't lift the handle halfway to get a little water because the handle falls to the off position.
Sounds like the collar that locks down the stem is in need of tighting to get some resistance to hold handle in place.
Remove handle to acces this collar and to tighten.
May 05, 2011 | American Standard 4205.100.021 Reliant+...
Upon installation of a one handle Moen shower valve, water flows immediately in the off position (6 o'clock position) then reduces as valve turns counter clockwise until fully off at 12 o'clock, then comes...
you need to adjust the little gear like..plastic part under handle..plus hot water must be on so that the pressure is balance..the cartridge also needs to be adjusted so water is off on off position
Nov 25, 2010 | Moen & One Handle Tub & Shower Faucet
Attempted to update a single level "diamond" ball shower handle for an older Delta 600 series. Everthing seemed to go well, but when I turned the water supply back on, and when the handle was pointed...
On a single lever shower handle, when the handle is pointing straight down the water is off. The handle will then rotate 270 degrees to the right through cold - warm - hot. What has happened is when you took the other handle off the new handle didn't go into the same position as the old one. So now when the handle stops at the down position the valve is still open probable running cold water. The fix is to take the handle back off. Rotate the valve into the off position so that water stops flowing and reinstall the handle pointing down. Now when you rotate the handle to the right you will get cold then warm then hot at 270 degrees and back to off when the handle is pointing back straight down. If you are still having problems please let me know and we will examine it a little closer.
Jul 18, 2010 | Delta Home
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
Which positions of the handle divert waater
The 'stop' is opposite the direction the handle extension points, so in the picture shown with this post the port pointing left is closed and the ports facing down and right are open.
Jul 31, 2009 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Handle lowers on its own, and hot water almost shuts off.
If you remove the handle on the faucet, you will find a grey or white retaining washer that has a couple of notches on it. Tighten this retaining washer and this will solve your problem.
Mar 31, 2009 | Rohl A3608LMPN Single Lever Country...
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
335 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
