Question about GE JGBP28 Gas Kitchen Range
Top burners often wont light if oven is already lit
GE JGBP28GEJIBG ser no HZ2541615L My burners only click (igniters) but wont light if oven is on first... always light correctly if oven is off , can light oven if burner is already lit , although more frequently the oven doesn't come up to temp , say 200-250 degrees when set to 400 , when lit by itself or with burner on. I replaced the oven igniter @ 4 years ago , seems to work. Local technician said replace the pressure regulator , haven't done anything yet. Thank You
  • 171 Answers
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Posted on Dec 07, 2008
Our burners light but when you turn the oven on you can smell gas. Can you tell me what is wrong
most of these will have the oven bake ignitor become weak and not ignite the gas when turned on.
you should see the bake ignitor try to glow orange but the gas will not lit to the burner.
without a digital meter to read the current, should be 3.2-3.5 amps then you wont know if the ignitor is weak.
you could try to just replace it and see if that fixes you trouble.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
my ingnitor is clicking but my overhead burners wont wont ignite.
Oct 29, 2008 | Hotpoint RGB745 Gas Kitchen Range
Stove-top burners
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Oven and broiler will not light.
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
May 10, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Aug 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP28 Gas Kitchen Range Logo
302 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
