Wobbles when spinning
I think the problem is the balance ring; it has lost fluid
  • 1 more comment
  • fivew300s Dec 07, 2008
    I believe the problem is the balance ring. The washer acts like a weight on a tether; it wobbles eccentrically at the very beginning before it reaches much speed and sitting on it does not even prevent wobbling. I have leveled the washer as much as the legs allow me to. I don't think not being level is the problem.
  • fivew300s Dec 08, 2008
    Kenmore model 11092573200
    Thank You.
  • aggie91 Jan 01, 2009
    I am having the same problem. I cannot find a schematic online. May I possibly get one also? Same model #. Thanks
  • 750 Answers
Hi thanks for using Fixya.com
The washer is not level or it has a broken spring or strut causing the wobble of the whole machine.
this requires hands on service! it is a job to change these!
please remember to leave a rating before you leave the site
Posted on Dec 07, 2008
  • Neil Golan
    Neil Golan Dec 07, 2008
    If it has even one bent support or broken spring or strut causing the wobble of the whole machine.
    send me the Complete model number and I'll send you the schematics and diagrams
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Constant out of balance on washer
Check the inter tub ring you should hear water when you spin it by hand
if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle
h Tech AL Wojo
Apr 01, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag mah55flbwq not draining
Perfectly normal..
What you are actually hearing is a balance ring on the inner tub that has liquid inside to help keep washing loads balanced.
The balance ring is filled with a calcium chloride solution and baffles within the ring allow the fluid to disperse within the ring evenly
By rotating the spin basket you can hear the fluid dispersing within the baffles of the balance ring.
Thebalanceringisfilledwithacelciurnchloridesolutionandbaffles,withintheringallowthefluidtodispersewithinthe:ring,evenly
I also thought ours was not draining properly but discovered otherwise when I had to take the inner tub out for a bearing repair job..
Hope this puts your mind at rest..
Aug 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
MW511. Pride The wash bowl seems loose and will not spin. I can hear the motor working but no spin is occurring. Will wash and rinse but not spin. It seems balanced on the floor. Would something have come...
The drum is meant to be wobbly, to a certain degree, you might want to get that looked at, but sounds like you need to replace the spline drive, under the wasing drum, remove the agitator, top deck by the 2 screws under lid and lift, then remove the neck ring it just clips on then the wash drum WILL pull out, then in the center you will see the spline drive housing, it has 3 screws, remove these screws and remove, both parts you can see make up the spline drive, replace and put back together in reverse order
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
25mph to 50 mph tire wobble
It could be a couple of things the tires could be out of balance and need rebalanced on the machine or it could of lost a weight from either the inside of rim or outside wherever your weights are located.
Feb 09, 2009 | 2003 Honda Odyssey
Kenmore Series 80 wobbles when spinning
the basket is attached to a triangular brace that must match up with the frame it sits on.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Repair failure.
Balance ring probably needs replacement.
Dec 15, 2008 | Washing Machines
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
Can you repair balance ring/tub unit on whirlpool direct drive washer or must you just buy a new tub? I think the fluid has leaked from the balance ring.
some units had balance held in place by clips those could be replaced separately those where balance slipped around outer edge of tub are not a separate part that can be ordered
Sep 17, 2008 | Whirlpool Washing Machines
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
