Question about Dayton (3E379) Heater
Wiring diagram for a Dayton thermostat
I have a Dayton model 2E468 and replacing it. There is one wire on the Dayton that is labeled number 4? The new thermostat as no # 4. What wire is this? I have heat and cooling.
  • Anonymous Mar 26, 2014
    How to wire Dayton 757 red wires
  • 108 Answers
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
  • jmckmcr Jun 28, 2011
    Dayton Electric does not seem to have a web site, unless it had a name change....JohnM
I need a wiring diagram for a Dayton model 3E402D gas heater
Contact Dayton directly and request a wiring diagram for a Dayton model 3E402D gas heater.
Jan 14, 2018 | Dayton Heating & Cooling
4-wire coming off living room wall. Needs direction to connect to Dayton 2E468 thermostat which has only 3 post with blue, white & yellow wires on 2 of 3 posts.
Must be a nice living room wall!! Do you honestly expect to get an answer to that? What's the unit, what's the old tstat, where were the wires landed before????? Help us so we can help you!!!
Aug 08, 2017 | Dayton Heating & Cooling
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
I have a Dayton Pahse 1, 3/4 HP motor that shows 115/230 volts on the label. I just had an outlet coverted to 240. I plugged it in and the motor barely moves and sounds like it is stuck or not enough...
there should be a diagram on the label for 110 or 220v-are you sure the last garage you ran it in was 220-it should only run at one of those levels without re-wiring the motor-cheers Denny
Oct 29, 2013 | Dayton Permanent Split Capacitor Motor Fan
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
May 21, 2013 | Pool & Spa
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
Oct 12, 2012 | Dryers
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
Need to disassemble a thermostat
  1. Pull the faceplate (bottom) straight out from the wall.
  2. Loosen the screws at the end of the wires, like the one in the middle at the tip of my middle finger.
  3. Remove the 2 screws which hold the rest in.
  4. Make a note of which wires were attached to what. I suggest taking pictures.
Nov 19, 2008 | Dayton (3E379) Heater
Dayton (3E379) Heater Logo
3,636 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
