Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 paper jam
Can't find a paper jam but paper won't grab on right side in order to print. power button keeps flashing like there's a paper jam
  • 31 Answers
Hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
hope this helps, cheers
Posted on Dec 07, 2008
Lexmark X1270 won't grab on right when I try to print
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 18, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark x1270 keeps jamming not grabbing on the right side.
Lexmark X1270. The paper goes to right and can not feed to print.
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Flashing power button on X1270
Go to the following website to contact Lexmark to help you with the solution:
LEXMARK SUPPORT
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this respond!
Feb 04, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3400 series paper jam
hmmm...well.that suggests that you have something along the left side
open up top and back, and inspect for any paper fragments
Aug 19, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
161 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
