Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
I have a Maytag Model MGR5770ADW and it appears that the left side door hinge spring is broken. How do I remove the side panel to investigate? Thanks, Ken
  • Maytag Master
  • 2,651 Answers
No need to remove the side panel, the door itself lifts off the hinges, and it will be reall obvious, if its broke, theres no servicing it just replace, and its done from the fornt, 2 screws and the hinge falls into the unit ( can grabit from pulling out lower storage drawer. part number (74011141) , might as well replace he 2 hinges one broke whos to say the right one is gonna last much longer
Posted on Dec 07, 2008
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Yesterday opened the door to dishwasher, and heard a thud sound. Now the door weighs a ton. I believe a spring/bracket broke, but can find no evidence of it. The dishwasher is working...
Either the door spring is broken or the linkage that ties the spring to the door hinge...the springs hook onto the leg/frame asm that supports the tub then the spring fit into that linkage and the liknage fits onto the door hinges.
This link is a parts breakdown for your model and item #6 is the spring and item #11 is the linkage..their is 2 of them (one on the left and one on the right) and its reccomended that both are replaced at the same time
Here is that link so are can get a good look of how and where they go
Sep 10, 2011 | Maytag 24 in. MDB4000 Built-in Dishwasher
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
yes you can.remove two screws from under one side pull it away slightly and it will come will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Apr 22, 2009 | Dometic RM2452 Refrigerator
How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Mar 24, 2009 | Maytag CWE4800A Electric Single Oven
Oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
Jun 05, 2006 | Maytag MEW5527B Electric Single Oven
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
196 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
