Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
Left side oven door spring broke. Maytag MOd. MGR 5770ADW
Spring is not working correctly. Would like info on how to remove side panel to inspect. How do I remove the side panel?
    Habit-Forming:
  • 171 Answers
No,no the side. but the broiler drower, remove it and look on the left and right sides. that's where are they are.
Posted on Dec 07, 2008
Tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
on Jul 21, 2009 | Maytag MMV4205 Microwave Oven
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
The 2 hooks(latch) inside the door have lost spring tension.
For no apparent reason, the latch broke on the 9187 ST. Take the door off of the microwave,which isn't too hard. Rotate the door to 90 degrees, lift up, and slide it to the left. Place the door on the counter, latch side up. Use a thin knife or screwdriver to lift the panel that covers the latch. It is very easy to remove it from the door. Then slide the latch up and lift is out. The spring is under the latch. The clip on the latch that held the spring was fractured. So, I drilled a tiny hole in the body piece from where the clip extended. I reattached the spring to the latch, replaced the panel, replaced the door, and it is as good as new.
Nov 11, 2012 | Samsung SMH9187ST Microwave Oven
Whirlpool dishwasher adp 962 - rinse aid/soap assembly
Hey- Tag should be visible with door open, left side. MOD.   Let's go over replacement instructions. Turn off power The door panel is held together by T20 torx screws. Remove screws, unplug the wires, and take off panel. Door is spring loaded, so place some weight on it to keep it down. Four 1/4" screws hold dispenser in place. Replace and re-assemble. Not too tough- just beware sharp edges! Let me know if this info helps- have more if needed- Thanks- Ed
Mar 17, 2010 | Dishwashers
Microve latch/spring assembly ... have a broken head on the latch which i can repair but cannot see where to attach other side of spring on Maytag MMV5207bas
Unfortunately, the exploded views do not show the innards of the door.
So as new latch head is not available separately, so if you cannot fix yours, a whole new door will be needed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
There's probably a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
You can use use epoxy and some kind of hardware to fashion a new spring mount.
If you have to do any gluing, make sure the parts are squeaky clean and dry before you glue them, or it will not hold up.
Oct 30, 2009 | Microwave Ovens
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
Mar 24, 2009 | Maytag CWE4800A Electric Single Oven
I have a Maytag Model MGR5770ADW and it appears that the left side door hinge spring is broken. How do I remove the side panel to investigate? Thanks, Ken
no need to remove the side panel, the door itself lifts off the hinges, and it will be reall obvious, if its broke, theres no servicing it just replace, and its done from the fornt, 2 screws and the hinge falls into the unit ( can grabit from pulling out lower storage drawer. part number (74011141) , might as well replace he 2 hinges one broke whos to say the right one is gonna last much longer
Dec 07, 2008 | Maytag MER5755QAS CleanDesign Electric...
Spring in door
I have the same problem. The end broke off. I heated the end with a torch and bent a new loop (cooled it in cold water). I hope it will work for a while. I could find a replacement on the internet. To get to the spring, just remove the left side panel (3 screws)
Jan 06, 2008 | DeLonghi EO1238 Toaster Oven with...
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
211 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
