Question about IBM ThinkPad 600X Notebook
I have a 600E that had the hard drive reformatted. I don't have a boot disk for the system (only has CD drive) but it won't boot from that when I try to reinstall Win 98. Got any suggestions?
  • jeannie0506 Dec 07, 2008
    CPU is 400 Mhz
    Hard drive is 20 G partitioned
  • James Raymond Williams
    James Raymond Williams May 11, 2010
    What speed is your processor (cpu).
    What is the size of your hard drive, (HDD)
    I am thinking if the above are large enough, then you can load XP from your cd rom. XP is a faster operating system than win 98.
    Sergeant:
    Champion:
  • 272 Answers
Your cpu is slower than I was thinking of. However you should be able to load XP. When you load XP remove all partitions and set it up on NTFS. Go for a full installation, load, anti virus and any utilities that you want. Get yourself an external hard drive and save all your folders to that after you have finished working on them. That way you will free up your cpu to manage. If you still want to load 98. Try going into the Bios and set the CD drive as your first boot option, with a bit of luck it may work. Once you have loaded your operating system be it 98 or XP, go back into the bios and re-set your boot preferences to HDD then CD Rom. Failing that I can not help you any futher. You may think of up grading to at least a P3 in the future. Another point. Borrow a copy of windows XP from a friend and install that, if it loads ok then you can obtain your own copy if you want to.
Posted on Dec 07, 2008
Cannot open my laptop... Did everything from removing the battery, cleaning the fan but still screen says non system disk or disk error replace n strike any key when ready.... Help pls
Please try the following:
1. Remove the non-system disk from your boot device. For example, remove the non-system disk from the CD-ROM drive. If there is no CD or remove the floppy disk from the floppy drive.
2. Change your computer's boot sequence. To do this, you must change your computer's setup and the option that controls which device your computer uses to start from. Make sure that you select a device that has boot files (or operating system files) installed. Normally, this would be your hard drive.
Oct 19, 2012 | Computers & Internet
How can i reformat my acer aspire 4520 without cd rom?
Try this method it may work.
If you can boot up with the external USB hard drive on your Acer, then use a working computer and copy the Windows installation CD onto the external hard disk then connect the USB externak hard disk to the USB port on your Acer and boot up using the external hard drive.
Feb 18, 2012 | Acer Aspire 4520-5141 Notebook
My laptop does not boot. it always ask for a cd to boot but i already reformat it.someone told me that it is a hard disk problem and advice me to replace my hard drive.
When the computer starts it flashes up press f2or delete or some other key to enter setup. Go through the settings and there should be one that will allow you to change the boot device. It sounds to me like it is set to boot from the cd rom drive only. Change it to boot from the hard drive and save changes to CMOS and restart the computer. The computer should now boot from the hard drive.
Aug 01, 2010 | Compaq Computers & Internet
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
How to reformat a notebook laptop with no CD-driver?
Remove the hard-disk - it will usually connect via an IDE or SATA-compatible interface. You can then connect it to a computer (internally, or via eSata / USB / 1394 enclosure). You can then format it from that computer.
When you say no CD-driver, do you mean Driver or Drive?
if there's no CD drive, it should either have a floppy drive (in which case, any system book disk can re-format the HDD), or USB-booting capabilities.
If there's no driver, than a Windows 2000 / XP CD should be able reformat the disk - when you boot from it, it will load drivers off the CD. You don't need to install Windows normally, the recovery console can format disks.
A Windows 95/98/ME boot disk/CD will allow formatting, but only in FAT/FAT32 file systems (you will probably want NTFS, which 2000 and XP can create)
Sep 05, 2009 | Computers & Internet
I cant reformat my hard drive. (Windows XP)
Hi. There are several causes for this type of error. Either your Windows CD is corrupted, hardware is faulty (Motherboard, RAM, hard disk, video card, etc.). You may want to try to reformat your hard drive using another computer first just to isolate if your hard drive is faulty. If you can format it using another computer, try installing windows on that computer.
Aug 27, 2009 | Microsoft Windows XP Professional for PC
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM 600E 2645 won't boot from CD rom
You can go into the BIOS and change the boot order of the drive devices,change the CD as the 1st boot device.
OR
As the laptop boots up, press F12, this will allow you to select the CD as a boot device.
Dec 07, 2008 | IBM ThinkPad 600E 2645 Notebook
600E 2645 won't boot from cd rom
u will have to go to your setup screen and reorder your boot screen so your cd rom will boot first so you can install windows 98, but if your cd rom isn't working you need to go to your device manager and look for your cd rom and install the driver
Hello the hard drive of our laptop needs a full reformat so i can reinstall xp but how do i format it without a working opperating system? thank you
 You can do a full reformat right from the windows xp install disk.  Put the xp disk in the cdrom drive and restart the computer.  Upon restarting a message will come up ( Hit any key to boot from CD )  Hit any key,  the files will load then you will be able to format the hard drive and also load windows XP.
    If for some reason your system doesnt boot from the cd, you might have to go into the Bios and change the boot order from the hard drive or the floppy to the cd so the computer will boot from the CD first. Hope this helps...                                                           Joe > Data Miner <
Oct 31, 2008 | Computers & Internet
IBM ThinkPad 600X Notebook Logo
159 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
