Question about Toshiba Satellite A135 Notebook
Oversensitive touchpad How do I adjust my oversensitive touchpad on my Toshiba Satellite A135. I tried doing this through the control panel but this didn't work. Wht do I need to do? Sharon
  • sharib60 Dec 07, 2008
    Thanks. I just had to reinstall my hard drive due to a virus that wiped me out and when I did this my touch pad became over sensitive. I will try finding a later driver on Toshiba's sight.
    I checked and this was not the case. Thanks. I also did an upgrade driver from my system and as thought...I have the latest version. Thanks for your help.
  • Toshiba Master
  • 5,568 Answers
Worst case, you could overlay the touchpad with the self-adhesive laminate used to protect photos. I would try it first without removing the backing to see if you can stand the loss of accuracy which will almost surely be a consequence of using it.
You might also check Toshiba's support section to see if there is a later driver with better control.
Posted on Dec 07, 2008
  • Steve Allison
    Steve Allison Dec 07, 2008
    There is a chance that the reinstallation caused Win to throw a generic mouse driver in instead of using the touchpad's software.
    You can look at the properties of the driver via the control panel, System, Hardware, Device Manager.
    Opening the mouse listing, you can get details with a right-click.
    Toshiba may make their own touchpad & driver but many manufacturers buy that subassembly from specialty companies.
Satellite A135-S4467 unable to click with the touchpad
there is a utility called ( alps touchpad) you can enter it from the tray by clicking on the icon ,,,, if not access it from the control panel ,,, this program controls tapping and clicking .... enable buttons clicking that should do it ,,,
Mar 07, 2012 | Toshiba Satellite A135-S4527 Notebook
We have a Toshiba A135 laptop with Windows 7 Home Premium. I would like to adjust the sensitivity of the touchpad, but cannot find how do make this adjustment. Please help.
Hi kipspal2,
You can adjust the sensitivity of the touchpad according to your requirement. Just follow the instructions below:
1) Click on Start.
2) Go to Control Panel
3) Double Click on 'Mouse'.
4) The Mouse Properties dialogue box pops up.
5) In the pointer options tab, under Motion, there will be a slider under 'Select a pointer speed'.
6) Move the slider with your mouse towards 'Slow'. Now you will notice that when you move your mouse, the sensitivity has decreased.
7) Apply the settings and Click OK.
Hope this information was helpful.
Thank you for using fixya,
Arun Zac
Nov 27, 2010 | Toshiba Satellite A135 Notebook
How do i turn mouse pad on and off ??
with the touchpads on my laptops, if you have the drivers installed, you should be able to go to the control panel, mouse settings and in there there should be something for turning the touchpad on and off. if the options arent there, maybe you need to get the drivers for it.
Apr 11, 2010 | Toshiba Satellite A135-S2276 Notebook
My keyboard and touchpad cursor are both frozen.
Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties in control panel
Mar 18, 2010 | Toshiba Satellite A135-S2246 Notebook
A135-4257 touchpad stopped working
Check to see the make of your touchpad (in most cases it would be a synaptics one.) If so, go to http://www.synaptics.com/support/drivers and download the corresponding driver according to your operating system.
NOTE
I'm assuming you already went through the basic steps such as checking if there's a dedicated touchpad button which might be turned off, checking if from control panel\mouse the device is not disabled, etc.
Nov 13, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135 S4527 PC windows xp service pack 3 drivers
Try uninstalling sp3 from add or remove programmes in control panel..because some of the drivers are not compatible with sp3
Jun 17, 2009 | Toshiba Satellite A135-S4527 Notebook
Touch pad refuses to work
Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite touchpad sensitivity
if you go to :
  1. control panel
  2. hardware and sound
  3. mouse
  4. device settings
  5. click the "setings" button
  6. then go to sensitivity
i hope this works as i have a toshiba a200 laptop. while you're there you can toggle palm check in case you lean on the touchpad.
Jul 24, 2008 | Toshiba Satellite A135 Notebook
Touchpad
Have you tried FN+F9? on my toshiba to reactivate glide pad I have to use FN+F9
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
