Question about Pioneer Audio Players & Recorders
My Pioneer model XC-L77 will not come on. It is connected to a power source and the fuse inside is good.
SOURCE: No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Posted on Oct 12, 2007
premtech
  • 934 Answers
SOURCE: Pioneer PDP42mve1 No Power
The resistor is a low ohm, probably in the smps, and the fact that it heated up was probably due to a short in the regulator. This is one you'll need to have serviced because of all the equipment you'll need to trace and diagnose the problem..
Posted on Nov 05, 2007
kenw392
  • 2226 Answers
SOURCE: have a pioneer car radio model deh-p3100ub has
do you have power going to both the red and yellow wires??? yellow is constant power (to retain memory) and red is switched (ignition). both wires need to see power before the unit will turn on.
Posted on Jun 11, 2010
SOURCE: The tray of my pioneer XC-L77 does not open when i
Just found your post - did you get a solution? I have already put mine into Pioneer once before and had it fixed. Now it is gone again. I am assuming it is a belt drive or something like a little fuse but haven't opened it up for a look yet.
Posted on Dec 22, 2010
  • 689 Answers
SOURCE: I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Posted on Nov 10, 2012
Nov 05, 2012 | Pioneer Audio Players & Recorders
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
I am installing a Pioneer DEH-1350MPG, i have connected all the wires but I have no power in the head unit.
Hello docabet2003,
Welcome, and thank you for using FixYa!
To answer your question: Check you in-line fuse on the power line, and trace the line back to the source fuse within the fuse box. Either of these fuses could be blown. If you hand wired your power source and ground; check to make sure the connections are secure (solid) at each end.
Also, check to make sure the stereo you are installing is designed to run off of a 5 amp fuse. If the stereo requires 10 or 15 amps, you will have to hand wire to an avaiable fuse within the fusebox.
Have a great day!
Sep 14, 2011 | Pioneer Car Audio & Video
Im hooking a cd player into my 93 toyota pickup ive got the ground and the power hooked up but nothings happening what the deal
A fuse may be blown inside the unit. Before you install it, check its' operation with an external power source (12 Volts DC) to make sure it works first. If it doesn't power-up, check the fuse inside.
Nov 02, 2010 | Pioneer DEH-15 CD Player
The tray of my pioneer XC-L77 does not open when i push the open-button. Can somebody tell me how to fix that?
Feb 10, 2010 | Audio Players & Recorders
How to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
Mar 27, 2009 | Pioneer DEH-P2900MP CD Receiver...
DOESNOT POWER AT ALL
Check All your wiring. Make sure you have a good clean ground connection, and that any inline fuses are good. Make sure the positive lead is hooked up and that any remote wires are connected to their sources.
Aug 12, 2008 | Pioneer Car Audio & Video
268 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
