On my Canon MX850 printer, the alarm light is on, the In/use memory light is on, and I can't print. Help! In use/Memory light flashes and clicksand can't use the printer. Nothing in user manual about it.
    Novelist:
  • 159 Answers
Please try upgrading firmware before doing anything else; new firmware was released just a few months ago. The firmware literally reprograms the printer to work differently. It's available here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=16279#DownloadDetailAct
Click on the tab furthest to the right, drivers and downloads. Then download the firmware (Mac or PC) and follow instructions.
That may not fix your problem, but it can have some beneficial effects. It won't do any harm, and can narrow down further troubleshooting if needed. Please post back if new firmware doesn't solve it.
Posted on Dec 07, 2008
  • 6,487 Answers
Try first tio power off the printer for 5 minutes unplug it from the power outlet then after that, check again if you still have the error message and if its gone try to printer and it should be working fine already..
Multifunction Canon mx 850 memory/in use light flashing ........will not print
1.Connect the phone line cord to the correct port on the MX850 :
http://goo.gl/Z8NPr
2.Disconnect and reconnect power cord to reset the device At the device or at the electrical outlet, disconnect the power cord or adapter. Wait approximately ten seconds and then reconnect the power cord. Wait until the device has completed its cycling process before submitting another job request.
3.Hang up extension phone .
Sep 11, 2011 | Office Equipment & Supplies
Mx850 canon all in one. was working fine then the alarm light came on and screen shows error code 6A00??? have tired moving the ink cartrigde device, unplugged and pluged back in ... checked everywhere...
6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
Dec 31, 2010 | Canon PIXMA MX850 Multifunction Printer
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Out of ink - Printer controls frozen ??
Press and hold the resume button for 5 seconds.
Oct 22, 2009 | Canon PIXMA MX850 multifunction InkJet...
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer displaying low ink level but ink level is enough yet,plz give solution
The Canon cartridges has a memory chip and the printer takes the information from ink level from this chip.You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer
to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
Oct 08, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Clicking sound and in use/memory light flashes. Canon PIXMA MX850
I had this problem and found that I had plugged the usb cable into the wrong plug hole. I had tried a reinstall of teh printer which failed when it tried to recognise that teh printer was on and connected. When I moved the usb cable to teh correcr socket (closest to teh side of teh printer) it was fine.
Brian
Jul 13, 2009 | Canon Office Equipment & Supplies
44 people viewed this question
jasbo
jasbo
