Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
ID quit registering
I have 2 vtech 5.8 phones. When a call comes in, all it says is ..ringing..there is no caller ID on both portable phones. Caller ID shows up on my other different phone ok. Did I somehow turn this off? If so, how to I get it back on.
  • baywindowboo Feb 04, 2009
    I have the VTECH 5.8 cordless phone the CALLER ID function is not working I know I should be getting it as it works on another phone.any help appreciated.
    Regards
Thank you...bgm1892
You solved my I.D. problem...
Thanks Again...
tpames@comcast.net
Posted on Apr 01, 2009
I just unpluged the system and pluged it back in. Didn't loose any information and it started working again.
Posted on Dec 07, 2008
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
How to set ringer from 2 rings to 4 or more on v-tech vtcs6114
The CS6114 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected to your phone, consult its documentation. If you need further assistance, please repost your question and identify the answering machine.
Feb 26, 2013 | New Vtech Vtcs6114 Dect 6.0 Single Handset...
CALLER ID
Have you tried using a diffrent phone as a test phone to make sure that caller id is working properly? Typically caller id takes 2 rings to register.
Oct 14, 2008 | Uniden Cordless Phone
I can not get my messages that are stored in the phone. Model # t2326. Cordless 2.4GHz technology
That model has Caller ID/Call Waiting and stores 30 calls. I f the caller ID does not display when the phone is ringing, assuming the display works, report to the local phone company. Make sure they have you turned on for caller ID service. If the calls are displayed when it rings but cannot be retrieved later, the phones is defective or they have been accidentally erased.
Aug 23, 2008 | Vtech Lands Phones
Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Jun 19, 2007 | Uniden DCX640 Cordless Expansion Handset
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
307 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
