Question about Canon PIXMA iP5000 InkJet Photo Printer
Canon Printer Problem : paper twists to right when loading
Canon iP5000 When pressing PRINT the paper at back of printer twists as it enters printer - it seems to pull too much at bottom right corner and stops printing with a PAPER JAM dialog box. I have tried every maintence procedure from Printer utility app and cleaned printer, held it upside down and shook it, and tried different brands of 80 thickness paper. The printer still works fine as it can do CD covers still. It just keeps twisting paper on entry. My next course of action will be to drop a large rock on it. Cheers Ian BTW printer has worked flawlessly for 18 months with no trouble
  • daveelisha Aug 25, 2008
    canon printer paper seems to go one side when i want to print something please help
  • rdoc Sep 13, 2008
    A4 paper sheet twists as the paper is 'grabbed' only on right side but not on the left side. So printing envelopes which are fed on the right side of the top feeder tray print okay, but not A4 paper.
Have the same problem I'd love to kick the s**t out of the person who designed this piece of rubbish I'll never buy anything by canon again. Had to refrain from launching the printer out the f**ckin window.
Posted on Oct 07, 2008
I find that having too much paper in the carrier can cause this problem.
Another tip I use is to fan the paper before putting it into the carrier and make sure the guides are guiding and not holding the paper, i.e. don't get them too wide or too narrow.
Posted on Oct 25, 2007
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Lines running through photos
Go into the print preferences and make sure the paper type is set to the right setting.Glossy photo,satin etc.Then print a couple times on regular paper to get the excess off the rollers.
Bob
Aug 09, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Loaded canon ip5000 driver with windows 7,but will not print through wireless netwrk
This printer is not designed for wireless. Use USB cable or direct print port.
Dec 26, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Jun 12, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printer error 1003
Bought an Epson printer. Cheaper than a repair
Jun 11, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Printer will not feed paper
Hi, Take the ink out, tip the printer upside down and give it a good shake! The problem is nearly always, something stuck in the rollers. Let me know how it goes!
Sep 23, 2007 | Epson Stylus 830U InkJet Photo Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
126 people viewed this question
old marine
old marine
