Question about Whirlpool Washing Machines
Wash machine wont spin
I have replaced the coupler and now i am checking the gear box. How do i get the gear box off?
  • 750 Answers
Here are some reasons for not spinning
It does not have to be a motor!
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
Check them out and see if this helps
Please leave me a rating before you sign off
Huum
Posted on Dec 07, 2008
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
Kenmore 90 does not spin (sounds like working & coupler is good)
If the coupler is ok then the next thing to check is the brake/ basket drive cam driver, the ear breaks off on em and won't release the brake. You must remove the agitator and drop the tranny to check itffbcc2d.jpg
Nothing is difficult about repairing the washer. I have repair photos HERE
Mar 13, 2010 | Washing Machines
Rab5232ew it will wash and pumps the water out
no belt, drive coupler it's probably broken and needs to be replaced. but if its the drive coupler it wont wash either so recheck it.if it still washes then check tub for object through holes jamming tub..you should be able to force the tub around by hand.
Jun 12, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Washing machine, kitchenaid, found brass looking pin w/hole in en
No,there are two such pins in the machine for shipping purposes only when it is shipped out,they drop out into little plastic cups under the machine after delivery,
 If it doesn't spin or agitate check the coupler located between the motor and gear box consists of three pieces two are plastic one on the motor and one on the gear box the other connects the two in the center it is rubber.
 If it spins but doesn't agitate,most likely a bad gear case.
Mar 08, 2009 | KitchenAid KAWS850LE Top Load Washer
Washer wont spin
if the coupler and clutch are ok and you can hear the motor functioning, then it appears that your transmission is bad.most of the time you will see that in the days/weeks leading up to this that your cloths were more wet than usual when you took them out of the machine. Check your owners manual for warranty information. Some machines had a 5 year warranty on the transmission or gear case as whirlpool likes to call it.
Dec 29, 2008 | Roper RAS8445KQ Top Load Washer
Won't agitate or spin model 110.24962300
GEARCSE NORMALLY HAVE A SMALL LEAK .BUT IF LEAKING MAJOR REPL/JUST SCREW ON BACK THE AGITATOR MAKING ANY WEIRD NOISE, USUALLY WHEN BROKEN COUPLER ,,SHOULD BE SIGNS OF GEARCASE BROKEN REPL
Nov 25, 2008 | Washing Machines
Kenmore 80 series washer not spinning
you need the gear box not the timer.
Dec 20, 2007 | Washing Machines
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
