Question about Bowflex Treadclimber TC5300
My bowflex tc5000 will not calibrate
When i try to recalibrate my bowflex tc500 they belts start to turn slowly and then just stop. How do i get the calibration to pass?
  • Anonymous Jan 05, 2009
    Will not calibrate-shuts off-"No Speed" on readout. Just another problem I"ve had with this piece of junk!!!!
  • ispcsi2 Jan 21, 2009
    Having same problem, will not calibrate and shuts down. Called Tread Climber----no response as of yet. Wish I had not bought piece of junk, just anoher of many problems.
  • 49 Answers
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Posted on Aug 31, 2009
  • Eric Angerer Aug 31, 2009
    if you remove the rear covers you will be able to see the lwr control board on the right side. Do not touch...Unit must be plugged in for this. move walk belt by hand and see if the green led light flashes. once it does then rotate back again to pass magnet by speed sensor. if it does not flash then the speed sensor if too far back or you have a connection problem
When i try to recalibrate my bowflex tc500 the belts start to turn slowly and then just stop. How do i get the calibration to pass?
Posted on Feb 14, 2010
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
How to lubricate tc500
Nice machine! I use WD 40 on my machine. It comes with a small tube attached to the can that lets you get into joints and bearings easily. Keep the can handy if you work out regularly..it keeps it quiet and smooth!
Jan 12, 2013 | Bowflex Tc5000 Climber Treadclimber...
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My tc5000 keeps failing the cal can you help
Try again RUN the software calibration. and adjust the REED SWITCH, and Speed Sensor, test it, clean it, and tight the plug or connector from UPPER board vs lower board.
God bless you
Nov 16, 2012 | Bowflex Treadclimber Tc5000 Tc 5000 W In...
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Can't get Bowflex TreadClimber TC5000 to pass calibration.
DEAR
AT FIRST YOU MUST REMOVE COVER AND SEE CAREFULLY TO FIND SENSORS SOME SENSORS ARE PHOTO SENSOR AND GET ON DUST AND CAN NOT GOOD WORK THEN BETTER THIS IS YOU CLEAN DUST VERY VERY GOOD PERHAPS SOLVE YOUR PROBLEM.
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 29, 2017 | Bowflex Treadclimber
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
The machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Mar 18, 2009 | Bowflex Treadclimber
Bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber TC5300 Logo
1,872 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
