Question about RCA P52960 52" Rear Projection Television
Flyback what is a flyback.. is that the same as a flyback transformer? Can I purchase online, is there a site I can go to, and can I replace it or do I need a tv quaified person.. I'm a granny..
  • 905 Answers
I read the other post you made and I don't belive that the flyback transformer has gone , and these models and makes from rca do have some common fixes that are found out by tech's . this problem that you are having can be in the power section , stanby circuit , protection circuit or even a horizontal output IC or some component that is causing the set not to come on . the flyback transformer would need to be tested to determine if it went bad but the power section would need to be tested first because there are different voltages that come out of the primary transformer and they go to different parts of the tv's functions and circuits , also info like what happen when it went out? and or was there a problem with it while watching it before it went out? , this can help to know what section was failing , thus start the testing in that section.
the best thing to do is to call an electronic repair shop to have a teck come out so they can determine the failure for you , as these are pretty complex sets and unsoldering and soldering , testing of and value idenentification of components is required , so if you cannot perform these then you could be putting alot of money into it and never finding the problem.
if you would like any more info , I'll bee glad to assist you
Posted on Dec 07, 2008
REPLACEMENT FLYBACK TRANSFORMER SONY TRINITRON CRT TV KV-2062E IS REQUIRED
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Sony Televison & Video
What is the flyback transformer number of sanyo tv ST-21SE1
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Flyback transformer data is given. Search the site with the keyword "Flyback Transformer". Type in these words in the search box located at the top right of the display window.
Jun 20, 2015 | Sanyo Televison & Video
Cannot Find Flyback Transformer 60PP9202/17F
Contact Philips directly. They should be able to get you the part, even if they have to get it from another repair shops. Many repair shops purchase their parts from factory authorized distributors, not from the manufacturer. The flyback transformer powers the tube-it can be extremely dangerous to work on-EVEN with the tv off, they contain a lot of power somethjing like 50,000 to 150,00 volts. It is not fun getting shocked by one of these as many techs have been knocked unconcious by them. If you do not know the proper procedure to discharge a flyback then leave it alone!
Dec 22, 2009 | Philips 60PP9202 60" Rear Projection...
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
52" rca projection screen tv
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback Transformer
Yes you can get the replacement flyback which is flyback 259296 at the following link and they provide free tech support to do the repair . Its a very easy repair takes about 20 minutes and requires the very basic soldering skills. heres the link.
May 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback transformer BSC 70Y
You will find the flyback on this site.
May 02, 2008 | Apex Digital PF3230 32" TV
Hitachi Multisystem TV model # C2980FS ..not powering on
First off you gotta tell us whats the right model and make as you have two listed here and both of these flybacks are avail. trough http://www.partstore.com. The parts are not listed online but get the toll free # or leave a message for them to get back to you. Now A flyback is not a user replaceable part for starters. It is soldered in and theres very high voltage inside these sets even after they are unplugged, and its not adviseable to replace a hi-voltage part in a set, unless you know the issues involved with replacing such parts. Good Luck
Jun 17, 2006 | Toshiba 35AFX54 35" TV
RCA P52960 52" Rear Projection Television Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
