Question about Garden
How to adjust nelson turbo heart sprinkler
How can i adjust to smaller area?
carlsbiz
  • 1124 Answers
SOURCE: Who do I contact to get parts for my Nelson
You should be able to find parts here
---> http://www.sprinklerwarehouse.com/
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
SOURCE: my nelson travling sprinkler wont move, just cicks
I* am certainly not an expert repair technition but I do own a Nelson traction sprinkler and did the following to mine.
I've not checked but I doubt seriously that the transmission is only ten dollars and I doubt if you can spray oil into the axles that it will last very long. The transmission is plastic and nylon and surely gets brittle over time so do not go nuts forcing it. The transmission is held to the casting with hexhead slotted screws. I did not even try to loosen them with a screwdriver as you will only strip the slots-use a socket wrench-they are surely stuck. With the bolts out the transmission is easy to remove. I could open the case about 1/4 inch before it would not go any further. I think you need to remove the part onto which the T shaped piece that the arms attach to. My sprinkler is quite old and I did not want to disassemble too much so with a clean dull old knife it was easy to apply marine waterproof grease to the gears and the axels. I then, reinstalled the transmission and hand turned the arms in both high and low gear to distribute the grease.
I works fine now with water and should last for another 20 years.
Posted on Dec 08, 2009
SOURCE: Nelson traveling sprinkler broken plastic part
I just took mine apart about a week ago. If, I recall correctly, you broke the T piece. That black plastic or nylon nut that is still connected to the transmission should thread off fairly easily.
I expect you can buy the part from Nelson.
If, solution #1 is correct and you find you cannot get the part, I've done some truly amazing repairs with that epoxy product called PC7. Depending how much of the part is broken and or missing, you might find a combination of what you have plus a brass T fitting plus the PC 7 will get it working.
You have nothing to loose.
heatman101
  • 43501 Answers
SOURCE: Do you know where I
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
heatman101
  • 43501 Answers
SOURCE: Need replacement gears for Nelson
heatman101
Sprinkler arms do not turn and the wheels do not turn on Nelson 1865
Here is a tip about how to get parts foryour traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
TravelingLawn Sprinklers
heatman101
Aug 08, 2011 | Nelson LR Rain Train Traveling Sprinkler...
I have a Nelson Pulsating sprinkler and can't figure out how to make it go all the way around
See if the stop that makes the sprinkler reverse by hitting the adjusting rings can be lifted up so that it doesn't hit the adjusting rings.
Gary
Jul 22, 2011 | Nelson Garden
I need to order gears for Nelson Sprinklers
heatman101
May 03, 2011 | Nelson Sprinkler: Traveling Tractor
Where can I order the Nelson Sprinkler Traveling Tractor?
Check this out they also sell new...
heatman101
Apr 28, 2011 | Nelson Sprinkler: Traveling Tractor
Need replacement gears for Nelson sprinkler. Can you help
heatman101
Apr 16, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Nelson travelling sprinkler. I have lost the stop device. Can I get another one?
heatman101
Apr 14, 2011 | Nelson Sprinkler: Traveling Tractor
Need replace ramp for Nelson Raintrain 1865 traveling sprinklers
heatman101
Aug 20, 2010 | Nelson Sprinkler: Traveling Tractor
My 1950`s Nelson tractor sprinkler has stopped running altogether. No water coming out anywhere.
heatman101
Aug 10, 2010 | Nelson Sprinkler: Traveling Tractor
I am looking for a manual for the Nelson Sprinkler Tractor. Are they available? Where do I find it?
heatman101
Aug 06, 2010 | Nelson Sprinkler: Traveling Tractor
Need parts for traveling tractor where can I get them?
Have you tried their website? These sprinklers are relatively expensive units as I remember. Well made and well worth fixing. Usually nylon gears with stainless steel shafts. Parts should be available through Nelson. Google: Nelson Traveling Sprinklers and see what sites pop up. If this has been helpful, please rate it accordingly. Good luck.
Jul 15, 2009 | Nelson Sprinkler: Traveling Tractor
Garden Logo
681 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
