Question about Vivitar ViviCam 3765 Digital Camera
Flash will only work in auto mode. used to work ok then suddenly stopped working in fill in etc. I thought it was that the batteries were getting low (rechargeables) but have changed them & only works in auto.
0 characters
1 Points
All photos suddenly too dark, even using flash.
If you are sure you are in automatic mode, the green camera logo on the top dial, your pictures have to be correct.
The exposure compensation should not be available in automatic, so that can't be the reason. (if you are in automatic)
The only thing you could look for, is the exposure metering. There you can chose 3 modes, and I do advise to chose Multi-pattern (should be default) because then not only the centre is measured.
If the pictures stay too dark, while in automatic and Multi-pattern, i think your camera is defect. It has nothing to do with the battery. If the battery voltage drops beneath a certain point the camera will stop completely and not work half.
Feb 16, 2014 | Kodak EasyShare Digital Cameras
Why is the flash not working on my vivitar 8025
The Vivitar 8025 has the following flash settings: Auto mode , Fill-in mode , Flash OFF mode. Since the cam doesn't have a manual flash setting, check to see if it's set to OFF mode. Or even Fill-in mode (sometimes it barely flashes). Auto mode will only work if needed......
Apr 08, 2011 | Vivitar Digital Cameras
Switches off when in record mode
Hi Patrick,
That happens to mine when the batteries are getting low. More so when the flash is on auto.
Try disengaging the flash and see what happens. If it works, replace the batteries.
Best regards,
Oct 06, 2009 | Praktica DCZ3.2S Digital Camera
S51 nikon - no flash
Did you try to access the flash mode of the camera and turn on the fill flash then try to take a picture? If the flash doesn't go then and your batteries are strong, then it will likely need service.
Make sure you put it on FILL FLASH and not on auto. Depending on the ISO the flash may not always fire in the auto mode.
Here's a link to the USER guide if you misplaced yours...
Dec 29, 2008 | Nikon Digital Cameras
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
Flash stopped working
I had the same problem, "BBWS" found this "solution":
Turn the camera on as if to take photos (not to review photos).
Press "Home" (upper left corner)
Press the camera tab (bottom left-most tab)
Press "Scene Selection (SCN)"
Press "OK" at the "Select type of scene" prompt
However, I still don't have flash available in the PGM or AUTO modes, which tells me it is still broken.
Jul 13, 2008 | Sony Cybershot DSC-T200 Digital Camera
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Feb 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Coolpix L10 won't flash in flash or auto flash mode
If you have the BSS (Best Shot Selector - page 79 of manual)...turn on then the flash or auto flash is over ridden and will not work. This happen as the BSS feature allows you to hold down the shutter release button (one used to take pictures) and continually take pictres, compare them and only keep the best one. The need to take rapids shots can not wait for a flash to recharge and go off so the flash is disabled... among other things but is all explained in the manual. I hope this is all your problem is and not something worse.
Nov 30, 2007 | Nikon COOLPIX L10 Digital Camera
Vivitar ViviCam 3765 Digital Camera Logo
13 people viewed this question
Top Vivitar Digital Cameras Experts
Are you a Vivitar Digital Camera Expert? Answer questions, earn points and help others
