Question about Toshiba 32AF42 32" TV
Want to use DTV converter with my Toshiba 32AF42
I just cancelled my satelite service to save money. I'm not sure how to check if I need an antenna and then how to hook up one of those new DTV converters before February. I went through the whole manual and couldn't find anything other than how to use cable or satelite. Please advise. :-)
Joan
  • joan_harbin Dec 09, 2008
    Thank you. This is exactly the information I needed to know. OK - so - now- where does one buy an antenna in 2008?! And how much do THEY cost? I have memories of that monstrosity that was attached to the house I grew up in. Do they still look like that? :-)
    Love your site.
    Joan
    President:
  • 2,992 Answers
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Posted on Dec 07, 2008
  • Dec 09, 2008
    DTV antennas can be large, but the broadcasts are in the UHF band which have always needed smaller antennas than the huge things for VHF. If you live in or near a metropolitan area you might not need more than
    an amplified indoor antenna, and they are available at most big
    retailers (Radio Shack, Target, Wal-Mart, etc.). They're cheap enough to pick one up to try before you decide you need one on the roof. I have put up a couple of different outside antennas from a company called antennasdirect.com and they look pretty neat and work well. Good luck and happy viewing.
I have no cable how do i program this tv set?
I assume you also have no satelite dish. You are probably on an antenna (or rabbit ears). If you don't already have one, you need a DTV Digital to Analog converter box. I am assuming you want to snag broadcast signals from the air, like in the good old days before the massive digital conversion of most broadcast stations. Might be hard to find one in retail stores, but start with WalMart or Best Buy, and if that fails you might check eBay (I think it is too late to get the government rebate which absorbed almost the entire cost of the box, but you might check around on Google searching on 'DTV Digital Analog Rebate'). The DTV converter will change the digital signal now being broadcast on most stations to an analog signal that your antenna connection will recognize. Without a signal, you can't program the channels because the tuner has nothing to latch onto. After getting a signal you just follow instructions for your TV to search for channels -- if you don't have instructions you might have to play around with the menus on-screen until you find what you need, but essentially it will be obvious when you see it ... the on-screen instruction will say something like select or program channels, and may let you choose manally or search automatically (choose automatically after hooking in the DTV converter to find all channels). Hope I understood your problem, your description is a bit vague.
Aug 29, 2011 | Televison & Video
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Cancelling cable
That model has an additional ASTC DTV tuner. Plug into the HDTV co-ax input from the DTV antenna.
Jun 03, 2009 | Polaroid FLM-323B Television
Does a CT-27614A need a digital converter for antenna?
According to http://www.dtv.gov/consumercorner.html#faq9
I hope this soultion is helpful.
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Panasonic Televison & Video
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
CONNECTING DTV CONVERTER AND STILL USING DVD PLAYER
Get a set of video cables to connect the DVD player to the TV.
Then follow the numbered instructions in this post to connect the DVD player, and use your TV remote to switch the video mode when you want to watch a DVD, then switch it back when you want to view TV.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 24, 2009 | Toshiba 32AF42 32" TV
Need to know if I need dtv converter for my Samsung combo tv
If you are using a cable TV or satellite service to get your TV content then you do not need a dtv converter.
You only need a dtv converter if you use an antenna to get your TV content and you do not have a digital TV with a internal digital tuner.
If you have the model # of your TV I can look that up for you if you are unsure.
Jan 12, 2009 | Televison & Video
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Upgrades
The DTV converter is only required if you use an external antenna. If you have cable or satelite, nothing will change. There are no other options.
Dan
May 23, 2008 | GE 25GT240 25" TV
Demo Mode wont go away!!
to turn off the demo mode on model 32af42 toshiba tv you can either press recall,exit or power buttons / if this fails enter the menu screen go to the setup menu highlight demo select stop .
Sep 15, 2007 | Toshiba 32AF42 32" TV
Toshiba 32AF42 32" TV Logo
277 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
