Question about HP OfficeJet V40 All-In-One InkJet Printer
How do i access the print cartidges on my hp officejet v40?
My all in one HP officejet is out of ink and I don't know how to access the print cartridges.
  • Anonymous Jan 06, 2009
    change cartridge
    President:
  • 1,901 Answers
Below is a link to the Setup Guide. Click on it and see steps 12 and 13.
V40 Setup Guide
Posted on Dec 07, 2008
Hp officejet j4580 flashing "incompatible
hello
you must purchase original ink cartridges -- not all compatible cartridges are built the same..
i would suggest buying authentica , from HP dealer or reseller
go to www.compluscominc.com, they will help you for sure and let you kno what to buy and how much
CC653AN icon_x.gif Contact Reseller
HP 901 Black Officejet Ink Cartridge - Prints approximately 200 pages (North America)
RoHS: Modified
CC654AN icon_x.gif Contact Reseller
HP 901XL Black Officejet Ink Cartridge - Prints approximately 700 pages (North America)
RoHS: Modified
CC656-30001 icon_x.gif Contact Reseller
HP 901 Tri-Color Officejet Ink Cartridge - Prints approximately 360 pages
RoHS: Modified
please send me 4 thumbs up
Aug 12, 2011 | Office Equipment & Supplies
How do i change the cartridge
See below: Also is a link the the manual for your unit the maunal has pictures: Page 62 of the manual list the procedure. (page 72 in the adobe file)
Manual
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
Feb 25, 2011 | HP Officejet 5510 All-In-One Thermal...
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Need help: our HP officejet v40 will not print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 06, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
My printer display says: "print cartridge problem [black] reefer to device documentation to troubleshoot." What do I do, I can;t get my printer to print. I just bought new ink, so the cartridge can't be...
Don
Oct 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Replacement instructions for ink cartridge carriage assembly
Please follow the link below to HP Web site. This will take you to the HP 7410 Setup Chart. The cartridge instructions you need begin in frame 10.
http://h10032.www1.hp.com/ctg/Manual/c00236206.pdf
Don
Oct 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet V40 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
