I have a problem, I've bought a P5Q-E Asus motherboard, and I've bought a 1066 Ddr2 ram, P5Q-e Supports ddr2 1200, and I'm scared what if 1066 won't work on this motherboard? Or will it, please help me out. And If it will work, will it run good? With no problems.
  • 32,281 Answers
It will most likely work, but it will make your computer run slower because the RAM you are inserting is slower then the one that is already installed.
Posted on Dec 07, 2008
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Which type of ram to fix in asus p5kpl-am/ps motherboard
2 x DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Maximum 4GB though.
If you go here:
http://www.asus.com/product.aspx?P_ID=y014Wy067iZxxPeP
and click on Memory/ Device Support tab you can download a document which is the Qualified Vendors List for available RAM for that particular motherboard.
Jan 26, 2011 | ASUS P5KPL-AM SE Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
I have purchased an ASUS ASUS P5K SE Motherboard. I want to run a MDT RAM at 667 Mhz DDR2, is it possible as it says nothing in the asus website The ASUS P5K SE Motherboard Qualified Vendors List (QVL)...
"The Asus P5K SE Motherboard Qualified Vendors List (QVL) says that it only runs ram at 1066MHz and MDT is not on the list"
Really? I beg to differ.
The motherboard manual states,
" The chipset officially supports the memory frequency up to DDR2 800MHz. Tuned by the Asus Super Memspeed Technology, this motherboard natively supports up to DDR2 1066MHz."
1) Notice the 'Up To'.
Supports UP TO 800MHz, and with the SMT it supports UP TO 1066MegaHertz.
It will support DDR2 at 667MHz, 800MHz, and 1066MHz (With SMT)
The QVL doesn't encompass all ram memory that is available out there.
The Ram Memory used has to be;
A) Unbuffered
B) DRAM chips used cannot be any larger than 64MB
[DRAM chip.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The Black rectangular chips, shown on the module of DDR Sdram example above, are DRAM chips.
http://en.wikipedia.org/wiki/DRAM
C) Should follow the JEDEC standard for DDR2 Sdram.
For one, it should follow the JEDEC standard for DDR2 voltage.
1.8 Volts.
Some high performance ram is set to use a slightly higher voltage. The Asus motherboard is set to use DDR2 at 1.8 Volts by default. (Factory settings=Default)
The MDT DDR2 at 667MHz is not high performance ram memory. It will be set to use 1.8 Volts.
Asus Support>Downloads,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Up to the Left side of the page is the heading - Download, in white.
Under it is the - Input Model to Search, box.
Put your mouse cursor in the box, leave it there.
Left-click once.
Type - P5K SE
Go to the Select Category box below it, and left-click on the down arrow, on the right side of the box.
In the drop down list click on - Manual
Now click on - Search info, below it.
Left-click on the blue P5K SE to the left.
Choose the Operating System. Left-click on the down arrow on the right side of the box. I chose Windows XP in the drop down list..
It doesn't matter.
Left-click on Search below.
Now scroll the next page down to Version E3202
Left-click on Global (DLM)
In the security box that pops up, make sure you use capital letters for the letters shown.
Left-click on Submit.
It's a PDF file download. Make take up to 30 seconds before you see the first page. May also take time to fully download. Advise letting it download before looking through it.
I posted the link so that if you have a motherboard manual, and it does not have the information this one has, then you now have the official Asus version.
Ram Memory information starts on Page 37.
Page 40 shows the QVL for DDR2 at 800MHz.
Page 41 shows the QVL for DDR2 at 667MHz.
This QVL does not list MDT either.
It's okay, it will work. The MDT ram memory has SPD support.
[Serial Presense Detect
http://en.wikipedia.org/wiki/Serial_presence_detect
Maximum Total Amount of ram memory is 8GB. You better have an O/S that will recognize 8GB, however, to realize this.
Has to be a 64bit O/S. (Operating System)
Windows XP Home, and Pro that are 32bit versions, will only recognize 3.2 to 3.5GB of ram memory.
Maximum Amount for EACH ram slot is 2GB.
If you only install one ram memory module, make sure it is in Slot 1. (DIMM A1 on that motherboard. The ram memory slot that is closest to the Processor)
350 Watt PSU? Not planning on gaming I see.
Depends on what PSU you have (Power Supply Unit), but it could be old enough to be just putting out 70 percent, of the maximum rated wattage.
245 Watts.
Continued in an additional Comment
Jun 07, 2010 | Computers & Internet
I currently have 2 x 1GB 667mhz ram in the yellow slot and I am thinking of buying 2 x 2GB ram but do I have to get the same Mhz or am I able to get a higher speed.
You have to buy the right "family" of ram. Your system needs DDR2.
You can buy any DDR2 and it will fit into your motherboard but your system specs are for DDR2 800 (also called PC2 6400)
You could buy 1066 (PC2 8500), which is faster, but it will run @ 800 instead of 1066 because your system is rated at 800.
So buy whichever is cheaper. Try to buy them in sets (matched pairs - 2 sticks of ram in same package).
Buy memory with good reviews (and prices) check newegg.com
Feb 16, 2010 | ASUS M2V Motherboard
Will this motherboard work?
in short, no
her cpu is a 775 socket, yours is 478 socket
her ram is ddr2, your is ddr1
would have to downgrade her parts to use your motherboard
Jun 08, 2009 | Dell Dimension 3100 PC Desktop
Supporting the DDR2 RAM
Asus site says the motherboard supports DDR or DDR2 RAM up to a max of 2GB.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=814&modelmenu=1
Oct 21, 2008 | ASUS P5VDC-MX Motherboard
I have an ASUS P5S899-VM motherboard and wish to install 2 x 1gb Samsung ddr PC3200 184 pin ram. Is this ram compatible with the motherboard? Many thanks, Colin Sinclair.
First you have to know the mother board supports the ram with ddr 1 and ddr2 . Now the new technology motherboard are supports only ddr2 ram and the ddr1 ram are consider as the older version. But ASuS P5S899-VM is contains the new technolgy of ram slot please see the manua or the mother board box. there you can see which it supports.please check it
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
