Question about Kenmore 46462 Front Load Washer
Have a whirlpool front load washer keeps flashing F 28 whats that mean?
    Scholar:
  • 91 Answers
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the lef t when facing
the MCU connectors.
What is the model number of your washer?
Please let me know if this answers your question. Thank you, Binary Bob
Posted on Dec 07, 2008
What does f-28 mean in a whirlpool washer
serial communication error / the communications between the central control unit (CCU) and the motor unit cannot be sent correctly go to www.servicematters.com look for L-78 PDF print it out but look for your own model just keep opening each one until you find it. and parts are pretty cheap on ebay and amizom. also believe or not but sears beat there price on some of the parts ive orderd hope this helps tammie
Mar 09, 2013 | Whirlpool Washing Machines
My washer keeps flashing and saying FH or Hf ... what does this mean?
Check to make sure you are getting a good supply of water to the washer. Remove hoses at the washer and make sure the filter screens are not clogged.
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F-28 door not opennig
Communication error . Usually means a bad connection between the MCU and the CCU or one of these components are bad.
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-28 flashing. Door will not open
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
Check your washer plug to see if the connections are tightly screwed. You can also plug off for half an hour to reset.
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool AWM6100 front loading - door open when not!
it's probably the innerlock, is the door locked?? if not it could be the innerlock
Mar 09, 2010 | Whirlpool AWM6100 Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
