Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
2004 Dodge Stratus 2.4DOC oil pressure light come on after warm, when idling or at a stop. Car has 94K miles
  • Anonymous May 07, 2009
    mine does the same exact thing... but mine is a 2003 with 96000 miles
  • 115 Answers
Change the oil sending unit on the back of the engjne.
Posted on Mar 03, 2009
  • mike ryner
    mike ryner Mar 03, 2009
    Make sure you check the oil level on the dip stick first . If it is ok then do the sending unit.
My dodge stratus 2004 the oil light is going on and off but the oil is not low
Could be a problem with the oil pump, the oil pressure sensor, clogged oil lines, or something more major.
Oct 18, 2014 | 2004 Dodge Stratus
I have a 2002 Dodge Stratus, When I come to a stop, the oil tight comes on but, when I take my foot off the breaks and asccelerate ( or put any gas to it) the light goes out. PLEASE HELP!
You are developing low oil pressure at idle this is a common problem with Dodge stratus. If you fail to have it fix you will definetly loose the timing chain and the whole enginecansmo_198.gif
Sep 11, 2011 | 2004 Dodge Stratus
Intermediate oil pressure light
Low oil level - add more.
Dec 04, 2009 | 2004 Dodge Neon
Oil light on at stop
engine oil pressure may be low remove oil pressure sending unit and install a pressure gauge check for pressure while warm if pressure is ok replace oil pressure sending unit oil pressure at idle should be between 5-15 psi at min
Nov 17, 2009 | 2006 Dodge Stratus
(2004 Stratus 2.7) The oil light stays on until the engine reaches about 1500 rpm. I want to test the pressure with a mechanical gauge. What is pressure at idle and what is maximum pressure (warm...
This same thing happened to me it was the oil sending unit that needed to be replaced. It's an easy fix but you have to take off the heat shield to get to it.
Nov 03, 2009 | 2004 Dodge Stratus
Ticking or clicking noise in the engine while at idle speed
The "lifters" are valve lifter, not oil lifters. They are best described as hydraulic cushions. They use the engine oil pressure to expand and take up the slack between components. As the engine wears, clearances increase and the oil pressure decreases at idle. The ticking goes away with an increase RPM because the oil pressure increases. Using an additive like STP to thicken the oil some might stop it. It isn't uncommon or serious. I had a car once that had lifter noise unless I used Rislone detergent additive to keep varnish from building up around the lifter making it stick. The symtom of coolant in the oil is milkey foam. Some synthetic oils go in clear then turn red or purple. Relax and enjoy the next 100,000 miles. Keep the oil and air filter changed and watch for a leaking water pump. Overheating because the water pump seal or thermostat failed is the death of an older engine. If you want to be proactive, have these and the radiator hoses changed. Avoid a made in China water pump if possible.
Jun 07, 2009 | 2004 Dodge Stratus
Oil light fickers or stays solid when braking
I had the same problem on a 2002 Stratus. I also had a Diagnostics Code of P0455(EVAP leak). I replaced the gas cap and this fixed the problem. I don't know what EVAP leak had to do with the oil pressure light coming on, but the new gas cap fixed it.
May 12, 2009 | 2004 Dodge Stratus
2004 Dodge Intrepid "jumps" occasionally when braking?
if your car has the 2.7 litre you have to change the oil every 5oookm or 3000 miles and use the exact grade as per the book.
the 2.7 has small oil galleries.
you have low oil pressure and or idle speed.check the rpm and it should be 700 unloaded at warm temp.if the iac controller is bad and there is low idle,really low rpm could trigger the oil light to come on and the transmission vacuum controls will be causing strange behavior.
May 04, 2009 | 1999 Dodge Intrepid
Where is the oil pressure sending unit on 2004 Dodge stratus
Most likely the oil pressure switch may be damaged. This is a simple procedure. Change and observe the results
Jan 23, 2009 | 2004 Dodge Stratus
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
