Enter setup password
When I turn it on all of a sudden it says enter setup password. I have had this laptop for several months and it has booted up right-a-way.
Why does my computer on bootup ask for system password then locks up too many attempts?
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Aug 16, 2014 | Dell Dimension 4600 PC Desktop
When I turn the laptop on I see the Toshiba screen for just a second and then it instantly goes to this lovely black screen that says password= How this got there I have know idea. Can anyone help?
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Sep 13, 2011 | Toshiba Satellite A105 Notebook
My son was messing with my laptop and now when i turn it on, it is a blue screen and asks for a password. (bios password). He claims he didnt put this on the laptop. So, how can i get the password or...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
now for the password
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
Apr 16, 2011 | Computers & Internet
Hi How do I clear BIOS password set by misstake on Acer Travelmate 2413 LCI? I can not get in to BIOS setup
When you turn on computer look for Acer logo on boot up. Press F8 or F10 or F2 while the logo comes up several times (if you miss turn it off and try again)and then you can access your bios. Use arrow keys and enter to clear the password. Follow the bottom of the screen for directions and if you need more help let me know and thanks for using FixYa.
Feb 01, 2011 | Acer TravelMate 2413LCi Notebook
My laptop was running a bit slow and i pressed f8 when my laptop started and i set up a password, now i cant turn it off everytime i turn my laptop on i have to type the password in, before windows starts...
I think you need to enter the bios. when the system boots look for the message to enter the bios or setup . it might be "del" you need to do it before the message disappears and sometimes the message does not appear for long, inside the bios setup you should be able to disable password requirement.
Dec 19, 2010 | Computers & Internet
Hy i have laptop dell x 300 latitudine and i dont now the password
  1. Restart your computer.
  2. At the first text on the screen or when the Dell™ logo appears, tap <F2> until the message Entering Setup appears.
  3. Fro there disable the System and Hard Drive Passwords.
  4. F10 to save and exit.
new_note.jpg Note: Some older Dell computers use an alternate key sequence instead of <F2> to enter System Setup. These key sequences include:
  • <Ctrl>+<Alt>+<Enter>
  • <Delete>
  • <Fn>+<F1> (laptop computers only)
  • <Fn>+<Esc> (laptop computers only)
Nov 09, 2010 | Dell Latitude X300 Notebook
I'd like to remove or replace the password so I can use it for internet.
to remove the password take the following steps
Insert your Windows XP CD into your CD drive and boot your computer. If you receive the message "press any key to boot from CD," press any key.
  • Step 2 Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process.
  • Step 3 Press R to begin the Repair process. Setup will now check your disks and then start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD).
  • Step 4 Keep your eye on the lower left hand side of the screen. When you see the Installing Devices progress bar, press SHIFT + F10. This will open a command line console.
  • Step 5 Type NUSRMGR.CPL at the prompt and press Enter. This will give you access to User Accounts. Remove or change your password. Write it down! After the repair is finished, you will be able to log on with your new password.
  • Read more: How to Remove an Administrator Password in Windows XP | eHow.com http://www.ehow.com/how_4464321_remove-administrator-password-windows-xp.html#ixzz0sPSURE3v
    Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process. Press R to begin the Repair process. Setup will now check your disks and then start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD). Keep your eye on the lower left hand side of the screen. When you see the Installing Devices progress bar, press SHIFT + F10. This will open a command line console.
    Jul 01, 2010 | Compaq Armada 1592DMT Notebook
    My mother-in-law's IBM Thinkpad will not boot. When she turns it on, there is just a lock icon at the top of the screen. It is a secondhand laptop, but it worked just fine for a few months. What could be...
    Someone has got into the BIOS configuration and entered a Power On Password and when you enter the correct password you can then enter the BIOS to remove this password or allow the laptop to boot up into Windows.
    This password is stored on an EEPROM chip and there are no backdoor passwords available.
    The Power On Password is used to protect the laptop from unauthorized access.
    Dec 13, 2009 | IBM Computers & Internet
    HELP!! PLEAse!!!!!
    What you have done is put a BIOS password on your system, all you have to do is enter the password you typed after you hit F10 the first time when the system boots up. if the password does not work try hitting the caps lock key and entering the password again.
    May 07, 2008 | HP Compaq nx6110 Notebook
    Computers & Internet Logo
    89 people viewed this question
    David Payne
    David Payne
