Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We had a power cut and then turned T.V back on and it made a
We had a power cut then turned T.v back on it made clicking noises and the sleep timer flashes...there is nothing coming from the T.V at all.
Helppppp!!! Thank you.
  • Any Guy
    Any Guy May 11, 2010
    Can you tell me how many times the sleep timer light is flashing?
  • 58 Answers
Check all the fuses u will find the prob, every board has at least one fuse.
Posted on Dec 07, 2008
My television keeps turning off with in minutes
Go to the mean and select sleep timer off or hold power of button for 5-6seconds
May 30, 2016 | Televison & Video
Set sleep timer menu on a SLED2490
turn sleep timer on and a section should light up
Jun 09, 2013 | Sansui 24" Widescreen Led 1080P Hdtv
Honestly, I would just like to turn off the timer. It is in my office serving no purpose and making an incessant noise. any advice
You posted under Intermatic box timer.
There are three ways to turn off timer.
1) Turn off circuit breaker momentarily, disconnect black power wire that connects to terminal 1, and then cap off wire. -Or- remove all wires and cap off each wire, then take timer home and put on your lights or pool pump. Basic 120volt timer is worth about 40$+.
2) If you do not have access to circuit breaker, you can risk life. Wear gloves. Stand on dry surface. Use insulated wire cutter, and a) cut black wire that connects to terminal 1 and cap off wire and/or b) cut several wires one at a time and cap off each wire.
3) Remove trippers from dial. Result: 3 watt clock motor continues to run, but timer will not click on-off. You can still control whatever is wired to timer by clicking override switch back and forth.
Aug 09, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
My radio powers off every few minutes. Needs to be turned back on by the on-off switch. How can I stop it from turning off automaticly?
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 20, 2011 | Grundig S350 AM/FM/SW Radio
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
Oct 30, 2009 | Televison & Video
You have a problem with power supply take it to a television engineer
Nov 17, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My RCA Dimensia TV from 1987 started to do this strange thing where the screen will turn off and on by itself while a loud clicking noise would come from the back of the set. This sort of thing has...
from original owners manual
check sleep timer or alarm time functions
electronic protection circuit may have been activated because of a power surge
Aug 21, 2008 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Power issue.
I have been researching this TV and found that many had motherboard issues with this exact problem. The fix was to replace it. I would contact LG support ASAP and get it to a service rep before the 1 year warranty runs out. Good luck!
Nov 16, 2007 | LG 32LC7D Television
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
