Question about Panasonic PT-52LCX65 44" HDTV
Panasonic PT 44LCX65 has a hazy screen after replacing the lamp
We just replaced our lamp in our 44LCX65. The picture is now really grainy. Any thoughts?
    Genius:
  • 1,148 Answers
CONVREGENGE IN THE MENU TO FIX THE COLOR
Posted on May 15, 2009
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
Replaced the lamp a year ago now the picture is dull and the vivid doesn't help.
Check its ballast. Normally ballast too might have replaced with the lamp.
Feb 01, 2013 | Panasonic PT-44LCX65 Television
Hi, my picture is very dim and when i try to compensate with adding brightness i get red outlines on the whites. Is it probably the lamp that needs to be replaced?
Yes,after you replaced the lamp,the picture get brightter.If u still have red outlines with white u have another problem,it ur convergence is dead also.
Mar 27, 2010 | Panasonic PT-44LCX65 Television
Pt-44lcx65
That seems it might be an issue with your ballast. With time this could cause the picture to go away, discountdashmerchantdotcom
Jul 26, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Green tint to bright spots on screen
Try to observe the problem when there is a white screen or predominantly white screen. If the screen is green or yellow where it should be white, its most likely a problem with one or more of the small LCD panels in the TV's light engine.
Its an expensive problem to fix. The light engine most likely will have to be replaced. Check with Panasonic customer relations for possible assistance.
michtech
Jan 30, 2009 | Panasonic PT-44LCX65 Television
I have a Panasonic model # PT-44LCX65 TV and have just replaced the lamp, as it was time to do so. A pink dot, that appeared before the old lamp needed replaced, remains on the picture. How is this fixed?
There are a few other threads on this board with the same issue, some say green spots, some say red spots, in my case it was blue/purple spots, but the solution is the same for all of them. Contact Panasonic and tell them that you read online that they are offering a warranty repair for this known "fuzzy spots" issue. They will send out a local repairman who will perform an EEPROM update to one of the computer chips inside of your TV, and viola good as new.
That is what others on this site suggested to me, and I did it and got all repairs covered under warranty by Panasonic even though my TV is 2+ out of the warranty period.
Jan 16, 2009 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 - all of a sudden will go blank and ten come back on and then it will go blank again - sometimes this goes on for the whole evening - other times only a few times.
Intermittent loss of picture is most often brought on by an intermittent lamp or ballast board. When you lose the image, look at the rear of the TV for light coming through the ventilation vents. If you don't see any light, its likely the lamp or ballast. If your lamp has more the 3000 hours on it, replace it regardless of whether its the only defective component. It will fail just when something good is on TV!
michtech
Dec 27, 2008 | Panasonic PT-44LCX65 Television
How to reset lamp timer
While pressing the VOL- button on the projection display,
hold down the PIP button on the remote control
simultaneously for more than 5 seconds. You will see a screen pop up that says "Lamp time was reset to 0" and the lamp indicator light will go out.
Dec 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
