Question about Coleman Powermate Premium Plus 6250W Portable Generator
Colman powermate 6875 generator engine runs but no power outpot
Generator engine runs but no power to outlets. pushed reset switches no help. called colamans 1-800 number and they said it needed renormalized. tried that still no help.
  • 169 Answers
I posted an answer that should help, click here.
Carl
Posted on Dec 08, 2008
HOW DO I USE THE 240 CORD THAT CAME WITH MY 5000W. COLMAN POWERMATE
It is a twist-lock plug, just push it in and turn to the right. Link to the manual:= http://www.powermate.com/pdfs/2007/11/17/manual_pm0435003.pdf
Jun 13, 2011 | Coleman Powermate Portable Generator...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6875, Does it have an auto idle???
If you've got an auto idle function you'll also have a switch somewhere to shut it off, so look for that first.
Engine surging is almost always a problem somewhere in either the air cleaner or the carb. Check the air cleaner, if it's not dirty take the bowl off the carb and look for dirt in the bottom.
Regards,
Carl
Feb 02, 2009 | Coleman Powermate Powermate 5000W...
TWIST PLUG
go to an electric supply store and let them know it is a 20 amp plug. The big box stores only have a few selections of plugs
I had the same generator and had to modify the plug to make it fit correctly
Jan 08, 2009 | Coleman Powermate Powermate 5000W...
I have a 5000w colman generator w/ 2 standerd 120v outlets, 1twist 120/240v outlet. the grounding prong goes out all i can find are cords that go in ???
Go to an Electric supply store and tell them it is a 20 amp plug. They should be able to get the correct plug.
I had this generator and had to adjust the prong to make it work.
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Wont turn over
Check the oil level, these generators have an oil monitoring system that prevents the engine running if the oil isn't all the way up to the bottom of the threads in the oil fill hole.
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
COLEMAN POWERMATE 6875 11 HP GENERATOR
Hello, If your generator has sat for a long time, the residual magnetism in the field coil may have dissipated completely this will cause the generator to produce no electricity. If this is the case there is a fix that is so simple it will amaze you by how easy it is to get it running properly again. The process is called flashing the field and it is done with an electric corded drill. Here is a link on how to do it. http://www.perr.com/tip16.html I hope this helps. If my solution works for you would you kindly give me a positive rating. Thank you, Michael Burke
Nov 01, 2008 | Coleman Powermate Medium Generator Cover...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
816 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
